Anonymus Raccoon 0 Posted November 4, 2018 Posted November 4, 2018 Hello, i started using emby on a synology nas this week and everything was working fine. This morning i wanted to setup the https connection with emby so i have setup an ssl certificate and used the settings: "Secure connection mode" to "Prefered but not required". Than, the emby server restarted but now i can't start the emby package. Every time i start the package from the synology's package manage, emby stop without even being able to access to the website. Thanks.
Luke 42241 Posted November 4, 2018 Posted November 4, 2018 Hi there, can you please attach the emby server log ?thanks.
Anonymus Raccoon 0 Posted November 4, 2018 Author Posted November 4, 2018 Here are the logs generated in the EmbyServer/var/logs folders when starting the package. I don't know witch one is usefull so i've uploaded them all to google drive. You can see them here: https://drive.google.com/open?id=16hEg61FtpnN_PpPAuPzI3qbHNMPHSdMA
Anonymus Raccoon 0 Posted November 4, 2018 Author Posted November 4, 2018 Ok so i've figured that the emby server stop everytime somebody try to access the site with an https connection. The website doesn't work in http (Unable to connect error in browsers).
Solution Luke 42241 Posted November 4, 2018 Solution Posted November 4, 2018 Looks like the server is being denied access to bind to the port. Did you customize the local port number? 1
Anonymus Raccoon 0 Posted November 4, 2018 Author Posted November 4, 2018 I feel totaly dumb. I was manually redirecting the port 443 to my nas. Thanks for your answer, it now work fine.
