JotNarayan 4 Posted November 4, 2018 Posted November 4, 2018 Goodnight. In previous messages, I mentioned the lack of server stability running from Nas Synology. Well, I just discovered a topic. After the innumerable tests, I told you that with the installation of version 3.5.3-8 and then 3.5.3-16 the thing had improved a lot and is currently stable. It is stable, from the android mobile phone, it is from the Windows10 PC, from the tablet in andrid. Your sharing is good. The only device that gives me problems is from the television "LG Smart TV (43UF6807-ZA)". I go back and forth through the Emby menus and it ends up blocking and it just resets, and when I say the solo, I refer to Emby's software on television. Viewing the logs of the server, the only thing that is detected is that the TV has disconnected from the server: ---------- XXX has disconnected from LG Smart TV (43UF6807-ZA) 11/3/2018 23:51:59 IP Address: 192.168.xxx.xxx --------- The whole problem lies either in the Emby app for LG Smart TV or in the television software itself. I wanted to record this topic.
