Mandus 0 Posted November 3, 2018 Posted November 3, 2018 hello, i have created multiple certificates in sslforfree and zerssl, i try to use either of them with my noip dynamic dns but i always get error in my browser. [Windows does not have enough information to verify this certificate] [The issuer of this certificate could not be found] i have my noip portforwad port 80 to 8920. in the emby settings i put my domain.net there and 8920 for https port note that when i type my domain it changes to myip:8920 even when i have masked url enabled in noip anyone can help?
Luke 42216 Posted November 3, 2018 Posted November 3, 2018 Are these certificates that the browser will trust?
Mandus 0 Posted November 6, 2018 Author Posted November 6, 2018 Are these certificates that the browser will trust? yes, they should be, is there a way to make sure of it? this is what chrome give "NET::ERR_CERT_AUTHORITY_INVALID." zerossl is compatible with all major browsers https://zerossl.com/ssl-faq.html#Which_browsers_will_trust_my_certificate_
KMBanana 116 Posted November 6, 2018 Posted November 6, 2018 Are you trying to use a certificate for a domain you own (mydomain.net) with a noip dynamic dns URL (something.noip.org)?
Mandus 0 Posted November 6, 2018 Author Posted November 6, 2018 Are you trying to use a certificate for a domain you own (mydomain.net) with a noip dynamic dns URL (something.noip.org)? i have my domain that i own on noip, i use their dynamic dns.
Mandus 0 Posted November 15, 2018 Author Posted November 15, 2018 i am still trying to get help in this topic.
Luke 42216 Posted November 15, 2018 Posted November 15, 2018 I'm not quite sure, it sounds like something particular to your SSL cert. Does your certificate documentation say that it works with your DDNS provider?
Mandus 0 Posted November 23, 2018 Author Posted November 23, 2018 I'm not quite sure, it sounds like something particular to your SSL cert. Does your certificate documentation say that it works with your DDNS provider? do you have a recommendation for SSL cert provider? or someway to do it?
