Kimballslice1890 8 Posted November 2, 2018 Posted November 2, 2018 I have a Nexus 9 32GB LTE (International Version [use it as wifi only though]). I like to use the tablet on road trips to watch my Emby content. I have the Emby app installed. Whenever trying to stream content on the Nexus 9, I regularly get a green and pink jumbled image or it is very choppy... like a low framerate and the video is way behind the audio. The only temporary solution I found for this is to force the quality to 720p -1mbps. Anything higher than that will cause it to be choppy or green... is anyone else having this issue that can recommend a solution? when setting the quality that low on a 9 inch screen it is definitely noticeable. Seems to be unique to Emby, Netflix and Plex work fine on any quality. Tethered internet bandwidth isnt an issue either, usually getting 10-50mbps
Luke 42244 Posted November 2, 2018 Posted November 2, 2018 Hi, so it's direct playing when this happens?
Devdroid 23 Posted November 2, 2018 Posted November 2, 2018 (edited) Are you trying to play HEVC/x265 content? Maybe 10 bit? I get this problem on my Huawei Mediapad M5 unless I transcode to x264 (which it only does if I lower the bitrate quite a bit), because HEVC 10 bit playback is broken on that device (probably due to bad drivers). Edited November 2, 2018 by Devdroid
Luke 42244 Posted November 2, 2018 Posted November 2, 2018 Yea that's what i was about to get at, that we're probably direct playing it and then being affected by whatever problems the device may have with it's hardware acceleration.
