Luke 42244 Posted December 18, 2023 Posted December 18, 2023 Every emby app that displays the media info section now has this. 1
NailClipper 4 Posted June 18, 2024 Posted June 18, 2024 Is it possible to enforce this for all users, from server-side? They don't need those information. I prefer only me seeing them.
Luke 42244 Posted June 19, 2024 Posted June 19, 2024 4 hours ago, NailClipper said: Is it possible to enforce this for all users, from server-side? They don't need those information. I prefer only me seeing them. Hi, no, but more control over user settings is planned for future updates. Thanks.
NikeSwe 122 Posted December 10, 2024 Posted December 10, 2024 (edited) On 6/19/2024 at 1:36 AM, NailClipper said: Is it possible to enforce this for all users, from server-side? They don't need those information. I prefer only me seeing them. This. Admin should be able to decide if it should be an option to the users to see and toggle. Where to put it? In the user profile settings that admin can see. Edited December 10, 2024 by NikeSwe
Happy2Play 9812 Posted December 10, 2024 Posted December 10, 2024 1 minute ago, NikeSwe said: This. Admin should be able to decide if it should be an option to the users. Where to put it? In the user profile settings that admin can see. Technically the Admin has access all user's info for the most part not to say the user can't just change it though. Users-select user and click Edit this user's profile, image and personal preferences and then Display
NikeSwe 122 Posted December 10, 2024 Posted December 10, 2024 (edited) 31 minutes ago, Happy2Play said: Technically the Admin has access all user's info for the most part not to say the user can't just change it though. Users-select user and click Edit this user's profile, image and personal preferences and then Display Yes, but the option could be disabled and hidden per user if admin decides that. Edit: I have disabled it for my family but they could easily turn it on. But no biggie. Edited December 10, 2024 by NikeSwe
Painkiller88 250 Posted December 11, 2024 Posted December 11, 2024 23 hours ago, Happy2Play said: Technically the Admin has access all user's info for the most part not to say the user can't just change it though. Users-select user and click Edit this user's profile, image and personal preferences and then Display Will this work for the apps also or just for users using a browser? All my users use apps and i want to hide this infos. thanks
ivanthomson 12 Posted May 13, 2025 Posted May 13, 2025 I would like to see this feature implemented. There should be a way for Admin to turn this off if they choose. I'm not comfortable with my drive path and file name spread out across the bottom of the screen along with other info. I believe there should be a master switch for ON/OFF that turns on/off the Media Info Section altogether. If you turn it on, then there should be more switches to allow the admin to turn on/off the drive path, and other sub sections/information. Some people might not want the file path displayed but might like the other sections, or whatever they prefer. In addition, there should be a checkbox or something saying (display for ADMIN only in clients) allowing admin to see the section but no one else. My two cents. Thank you.
Happy2Play 9812 Posted May 13, 2025 Posted May 13, 2025 5 hours ago, ivanthomson said: I would like to see this feature implemented. There should be a way for Admin to turn this off if they choose. I'm not comfortable with my drive path and file name spread out across the bottom of the screen along with other info. I believe there should be a master switch for ON/OFF that turns on/off the Media Info Section altogether. If you turn it on, then there should be more switches to allow the admin to turn on/off the drive path, and other sub sections/information. Some people might not want the file path displayed but might like the other sections, or whatever they prefer. In addition, there should be a checkbox or something saying (display for ADMIN only in clients) allowing admin to see the section but no one else. My two cents. Thank you. Sorry I don't follow as there is a option and users do not see paths only admins. admin user non-admin user User setting But at the same time it is a USER setting that they can enable/disable at will. At the same time I personally don't see a issue with anyone seeing this info but I guess it is just me.
ivanthomson 12 Posted May 13, 2025 Posted May 13, 2025 4 hours ago, Happy2Play said: Sorry I don't follow as there is a option and users do not see paths only admins. admin user non-admin user User setting But at the same time it is a USER setting that they can enable/disable at will. At the same time I personally don't see a issue with anyone seeing this info but I guess it is just me. Hey thanks for that info. Being new to EMBY I am unfamiliar with many things. I wasn't aware the file path was admin only. That's good news to my ears. As far as the other info in the Media info section, I am aware users can setup their own preferences, but, I agree with others on here that it should be a site wide (is that the correct term, maybe server wide) setting under admin control. Some admins probably do not want to show the info (as stated in their previous comments). I understand some people do not care, but others do. I personally, do not like all that info there and use a custom CSS to hide it, but understand that only works in a webpage client, not in app clients. I feel it would be nice to give admins more control over the content displayed as opposed to less control. Thank you.
