dsmithp233 0 Posted November 1, 2018 Posted November 1, 2018 Hello, I'm running Emby version 3.5.3 & my issue is that in the Advanced section of Emby, if I uncheck "Allow remote connections to this Emby server" and "Enable automatic port mapping", click "Save", navigate to a different section in Emby and go back to the Advanced section, the options are checked again. I've tried two different browsers as well. Any ideas? Thank you.
Luke 42213 Posted November 1, 2018 Posted November 1, 2018 Hi, what is the value in the secure connections mode dropdown?
dsmithp233 0 Posted November 1, 2018 Author Posted November 1, 2018 Thanks Luke. I changed the secure connections mode option from "Preferred but not required" to "Disabled" and that fixed my issue. Thanks again.
Luke 42213 Posted November 1, 2018 Posted November 1, 2018 Thanks. That is actually caused by a defect from an older server version. It should have always been disabled without an ssl cert in place.
