dcol 176 Posted October 30, 2018 Posted October 30, 2018 The little green Emby icon in the taskbar is gone and it won't come back. I did use it in the past to open Emby and restart the server. Now it is gone. If I restart the Emby server, it appears for a brief second then disappears. Restarting the computer has no effect. I do not see any settings for this. Emby is running and is working. Had to add a shortcut on the desktop to open Emby in a web browser. How do I get this task back?
ebr 16312 Posted October 30, 2018 Posted October 30, 2018 Hi. Are you sure it isn't just hidden? Click the up arrow next to those icons...
dcol 176 Posted October 30, 2018 Author Posted October 30, 2018 (edited) There is no arrow. I have the taskbar set to display all icons. Besides, it does show up for about one second when I start the Emby server. Emby server is currently running and here is a pic of my taskbar. No new programs have been added since it worked previously. Just noticed it yesterday. Edited October 30, 2018 by dcol
ebr 16312 Posted October 30, 2018 Posted October 30, 2018 Try updating Chrome. What version of the server are you running?
dcol 176 Posted October 30, 2018 Author Posted October 30, 2018 Chrome is updated. Emby is version 3.5.3.0
Solution Luke 42213 Posted October 30, 2018 Solution Posted October 30, 2018 Did you configure Emby to run as a windows service? 1
dcol 176 Posted October 30, 2018 Author Posted October 30, 2018 (edited) Yes, I did. Is this ok to do? Edited October 30, 2018 by dcol
Luke 42213 Posted October 30, 2018 Posted October 30, 2018 Yes it is OK, but you won't get a tray icon when you do that.
dcol 176 Posted October 30, 2018 Author Posted October 30, 2018 Ok, Yes I did that a few days ago. I created a desktop icon so I can get to the dashboard. Thanks
