ddurdle 75 Posted October 30, 2018 Posted October 30, 2018 Using a port with 8097 with Emby. Using Emby connect. Works in every app except Emby on KODI. Using latest beta. I can see from doing a network sniff that when doing a sync, it's trying to use port 8096 instead of 8097. So, the plugin is connecting to the Emby on 8097 correctly at one point (such as perhaps for login and fetch of the library details), but when trying to do the initial sync, get a "sync failed" and I see traffic coming in on port 8096 from the user.
Angelblue05 4132 Posted November 11, 2018 Posted November 11, 2018 @@ddurdle Did you try to update the server information in the add-on settings > Update server information?
ddurdle 75 Posted November 11, 2018 Author Posted November 11, 2018 @@ddurdle Did you try to update the server information in the add-on settings > Update server information? I'll ask the user, I doubt they had. If it occurs again, should we update this to see if that fixes the problem? 1
Angelblue05 4132 Posted November 11, 2018 Posted November 11, 2018 I'll ask the user, I doubt they had. If it occurs again, should we update this to see if that fixes the problem? Yes please. Thank you.
