Guest asrequested Posted October 30, 2018 Posted October 30, 2018 (edited) Anyone use one of these HP expander cards with an LSI 9211-8i? If yes, does the 3GB bandwidth cause problems? https://www.ebay.com/itm/HP-487738-001-468405-001-24-Bay-3Gb-PCI-e-SAS-Expander-Card/172959134706?epid=2196419301&hash=item28452af3f2:g:CHsAAOSwDMNa8bMk:sc:USPSPriority!94975!US!-1:rk:6:pf:0 I'm looking to convert a 5.25" bay, with one of these, for my drivepool SSDs. http://www.ipcdirect.net/ss-204-4-x-2-5-sas-6g-sata-iii-ssd-hdd-hot-swap-storage-enclosure-for-one-5-25-bay/ Edited November 12, 2018 by Doofus
Guest asrequested Posted October 30, 2018 Posted October 30, 2018 It may actually be SATA not SAS. I'll find out when it arrives.
markyp 38 Posted October 30, 2018 Posted October 30, 2018 I wouldn’t have thought so but if I were you I’d spend a little more and get the 6gb version, just in case you want to expand some more...
Guest asrequested Posted October 30, 2018 Posted October 30, 2018 (edited) Turns out, it has four SATA connections. The product title on IPC is wrong. https://www.amazon.com/SATA-Swap-Storage-Enclosure-SS-204/dp/B00IPXOMLM/ref=sr_1_91?m=ATAV5SZ5JVR3C&s=merchant-items&ie=UTF8&qid=1540880241&sr=1-91 Edited October 30, 2018 by Doofus
PenkethBoy 2068 Posted October 30, 2018 Posted October 30, 2018 The HP SAS expander works fine - i have 24 drives (HDD) hanging off mine with the correct break out cable it should work fine with that enclosure The HP card only needs power - does not need to be plugged into a m/b pcie slot if you are short of them I suspect the enclosure needs SAS drives internally even though it has sata connectors on the exterior
Guest asrequested Posted October 30, 2018 Posted October 30, 2018 Yeah, I think you're right. Bizarre why they would be SAS internally but SATA externally.
Guest asrequested Posted October 30, 2018 Posted October 30, 2018 I was looking at the description. It seems to suggest that it supports SAS and SATA.
PenkethBoy 2068 Posted October 31, 2018 Posted October 31, 2018 Actually reading the description again on the Amazon Link - my view is that it takes SAS or SATA drives internally and externally sata to say your motherboard / sata card / SAS card (with breakout cable)
Guest asrequested Posted October 31, 2018 Posted October 31, 2018 (edited) Yeah, last night I was looking at some others. Thermaltake and Iceydock have some 6 drive versions. https://www.amazon.com/gp/product/B01MTK1GQ8/ref=ox_sc_saved_title_2?smid=ATVPDKIKX0DER&psc=1 Edited October 31, 2018 by Doofus
Guest asrequested Posted November 7, 2018 Posted November 7, 2018 Stupid fan controller died, today. Almost lost half of my drives New controller on the way. Until then, I have tornado in the room.
Guest asrequested Posted November 12, 2018 Posted November 12, 2018 I've got this installed, now. I love this thing. It works really well.
