toasty_mcboost 0 Posted October 29, 2018 Posted October 29, 2018 Hello, looking to get my home network figured out and then have it reachable externally. I thought I hit all the points - guess not.My setup:My install of Linux Mint. My fstab has been modified to mount at boot another drive so Emby sees it at startup and that part works. Going to http://localhost:8096/web/index.html#!/home.htmlshows the Emby homepage with my media. Problem is I cannot access outside of the box. I have samba installed too for file sharing and here is the section relating to the shared files[Movies] comment = Emby Movies path = /home/toast/Videos/Movies browsable = yes guest ok = yesI have also setup port forwarding as well. Emby TCP 8096 8096 192.168.0.13 N/A Edit x However as http://www.canyouseeme.org/ states my port is not open and cannot see me. The devices I am sharing to are a Roku 3 and my phone, neither of which are making connections when on my home network.
Luke 42246 Posted October 29, 2018 Posted October 29, 2018 Hi there, welcome. I would suggest checking out our connection troubleshooter: https://github.com/MediaBrowser/Wiki/wiki/Connectivity Please try the steps listed there and let us know which ones succeed and which ones do not. Thanks !
toasty_mcboost 0 Posted October 29, 2018 Author Posted October 29, 2018 I am the only user and will not be adding any others. The default with admin privileges will be fine.Dashboard IPsI have opened my 8096 port on my router however canyouseeme.org cannot see my machine or detect the open port.This is what my phones says when signing in with Emby ConnectPlaying locally off my machine where everything is being hosted is no problem.What else can I provide?
toasty_mcboost 0 Posted November 1, 2018 Author Posted November 1, 2018 I realized that all I had to do was enable the port on Linux just as I did so on my router.Hey Luke can you add this step to your setup guide so people are aware of it? To open the portsudo ufw allow 8096/tcpTo verify that it workedsudo ufw status verboseI used this page to check my workhttps://www.cyberciti.biz/faq/how-to-open-firewall-port-on-ubuntu-linux-12-04-14-04-lts/
Luke 42246 Posted November 9, 2018 Posted November 9, 2018 Yes we can do that. Thanks for the feedback !
