JotNarayan 4 Posted October 28, 2018 Posted October 28, 2018 Today I installed the new version 3.5.3.0-16 and I have problems with updating the libraries. I had installed the 3.5.3.0-8 and it worked perfectly, but with this new one when I add new series, the system is not able to locate the corresponding tags, and if it does it stays half-way. Is it possible to return to version "8"?
Luke 42241 Posted October 29, 2018 Posted October 29, 2018 Hi there, can you please describe the issue that you're having? Thanks.
solabc16 379 Posted October 29, 2018 Posted October 29, 2018 Hello @@JotNarayan Please can you run the send logs utility: https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs This is still version 3.5.3.0 of Emby Server. Best - James
JotNarayan 4 Posted October 30, 2018 Author Posted October 30, 2018 I will try to capture the logs when there are new errors and I will send them. A question: Between today and tomorrow, I will migrate the entire installation to a new nas, the DS418play, which works with "Intel Celeron J3355". The current one that I have now is a DS218play that goes with "Realtek RTD1296" The performance for Emby, is better with the DS418play? Will the software work better? Thank you.
Luke 42241 Posted October 30, 2018 Posted October 30, 2018 If it has a faster cpu then yes it will be better.
solabc16 379 Posted October 30, 2018 Posted October 30, 2018 Hello @@JotNarayan The DS418play has an Intel 'apollolake' based processor, which will support h/w transcoding. So if your usage requires transcoding, then that's going to be beneficial. Best - James
JotNarayan 4 Posted October 30, 2018 Author Posted October 30, 2018 Thank you both, when I have everything installed and verified I commit the new operation.
