kbeck 64 Posted October 28, 2018 Posted October 28, 2018 (edited) All was fine then had a freeze up and had to end the program and suddenly my display is all messed up. Have Emby Theater on a desktop connected to a wide screen tv. Display mode is set to desktop. The My Media section is 1 long horizontal string off the right of the screen. Have logged out of Emby and back in. Restarted the server. Restarted the computer. Checked the user settings for Display. Edited October 28, 2018 by kbeck
kbeck 64 Posted October 28, 2018 Author Posted October 28, 2018 (edited) Change it to TV mode That makes it like 10x normal size. Plus it does nothing to the long horizontal bar. It is by design. Then why did it work fine until yesterday, and still has 5 rows on my other computer? Now it seems the 2nd computer has this view also. Great. Edited October 28, 2018 by kbeck
Luke 42242 Posted October 28, 2018 Posted October 28, 2018 Because we updated the design, and eventually your other machine will get the update as well.
kbeck 64 Posted October 28, 2018 Author Posted October 28, 2018 Yeah. It just did. This totally blows. Thanks for screwing up a perfectly good setup. Leave it the hell alone.
arrbee99 1836 Posted October 28, 2018 Posted October 28, 2018 Yeah. It just did. This totally blows. Thanks for screwing up a perfectly good setup. Leave it the hell alone. Sounds the same as was done on the web page when absolutely no one asked for it for no good reason. 1
SikSlayer 254 Posted October 29, 2018 Posted October 29, 2018 Sounds the same as was done on the web page when absolutely no one asked for it for no good reason. Getting REAL tired of these stupid changes no one asked for. I can't even change the mode because the option was removed. That's the part that takes the cake. Why remove the option?
kbeck 64 Posted October 29, 2018 Author Posted October 29, 2018 I didn't know this was a Microsoft company?
