streetlife 2 Posted October 28, 2018 Posted October 28, 2018 Hello, I have a weird remote control situation and I need some help. I have Emby installed on Laptop A (which is my primary computer). My TV is a bit of a distance away so I connect Laptop B to it via HDMI. I connect to Emby on Laptop A from B. My question is how to remotely control playback from Laptop A. Please help.
mastrmind11 722 Posted October 28, 2018 Posted October 28, 2018 Hello, I have a weird remote control situation and I need some help. I have Emby installed on Laptop A (which is my primary computer). My TV is a bit of a distance away so I connect Laptop B to it via HDMI. I connect to Emby on Laptop A from B. My question is how to remotely control playback from Laptop A. Please help. ? Put an emby client on Laptop B and control it from there?
Solution EODCrafter 181 Posted October 28, 2018 Solution Posted October 28, 2018 Hello, I have a weird remote control situation and I need some help. I have Emby installed on Laptop A (which is my primary computer). My TV is a bit of a distance away so I connect Laptop B to it via HDMI. I connect to Emby on Laptop A from B. My question is how to remotely control playback from Laptop A. Please help. https://www.amazon.com/REIIE-Wireless-Handheld-Keyboard-Raspberry/dp/B06X9J8NG4/ref=pd_lpo_vtph_147_bs_t_1?_encoding=UTF8&psc=1&refRID=M89WNHN03XC00Q007BJR 1
streetlife 2 Posted October 28, 2018 Author Posted October 28, 2018 There was a time I saw play/pause buttons under the remote client. How can I enable that or other features?
streetlife 2 Posted October 28, 2018 Author Posted October 28, 2018 https://www.amazon.com/REIIE-Wireless-Handheld-Keyboard-Raspberry/dp/B06X9J8NG4/ref=pd_lpo_vtph_147_bs_t_1?_encoding=UTF8&psc=1&refRID=M89WNHN03XC00Q007BJR Thanks. I'll check it.
EODCrafter 181 Posted October 28, 2018 Posted October 28, 2018 (edited) There was a time I saw play/pause buttons under the remote client. How can I enable that or other features? Using that to control playback is not feasible.....Try 1 of the many Emby Apps! https://emby.media/download.html Edited October 28, 2018 by EODCrafter
streetlife 2 Posted October 28, 2018 Author Posted October 28, 2018 Hello, The remote keyboard got me thinking. I eventually downloaded a universal remote app and controlling playback from my phone. Thank you. 1
Luke 42213 Posted October 28, 2018 Posted October 28, 2018 Try Emby Theater, it supports being controlled via keyboard.
