ashwin15 2 Posted October 27, 2018 Posted October 27, 2018 I have a tv guide of my own....like schedule direct or xml tv, I want to connect it with emby and sync channels so that I can play using my own guide. 1
ashwin15 2 Posted October 27, 2018 Author Posted October 27, 2018 (edited) I have a Hd home run device connected with emby and I am wondering how emby sync with scheduledirect tv guide and Hd home run device so when I click on a show through live tv it gets broadcasted. Edited October 27, 2018 by ashwin15
Sammy 791 Posted October 27, 2018 Posted October 27, 2018 (edited) Server Dashboard > LiveTV > LiveTV > TV Guide Data Providers > xmltv > [path to your xmltv file] Sent from my SM-G930P using Tapatalk Edited October 27, 2018 by Sammy 2
Luke 42237 Posted October 27, 2018 Posted October 27, 2018 @@ashwin15 please let us know if this helps. thanks ! 1
ashwin15 2 Posted October 29, 2018 Author Posted October 29, 2018 Thank you for responding quickly but I am not looking for the information that you have provided. I want to know that how emby connects a program id with any tv guide. So that when a person clicks on a program emby knows which program to play. 1
Luke 42237 Posted October 29, 2018 Posted October 29, 2018 First it matches the channels, and then it uses that to extract the programs per channel from the guide data.
ashwin15 2 Posted October 30, 2018 Author Posted October 30, 2018 Okay got your point but while inspecting channels and programs through emby guide they have different channel id and program id then both of schedule direct and hd home run.
singhbutes 0 Posted November 2, 2018 Posted November 2, 2018 Hello,I too was in the same situation around a month ago... wondering how its done... Have the same problem with me too... Is there anyone who can help me out with this?
Luke 42237 Posted November 2, 2018 Posted November 2, 2018 Hello, I too was in the same situation around a month ago... wondering how its done... Have the same problem with me too... Is there anyone who can help me out with this? Hi there, can you please describe your issue in more detail? Thanks.
singhbutes 0 Posted November 5, 2018 Posted November 5, 2018 Hi there, can you please describe your issue in more detail? Thanks. Thanks for your time Luke... Below is my query in detail I have an HD home run device which is connected to my home router and tuner. Now using Emby when its connected to Schedule Direct TV guide the channels from lineup.json of HD home run gets auto mapped with station id's of Schedule Direct and then using Schedule Direct API will get the programs and the metadata of program, up to this process I am clear. Now I want to know how Emby uses these channels & programs and display them on TV Guide screen so that when a person clicks on it they will be played because when inspected any program grid then channel id and program id is different from that of Schedule Direct or lineup.json
Luke 42237 Posted November 5, 2018 Posted November 5, 2018 Right, those are internal IDs generated by emby, but the mappings are in the database.
ashwin15 2 Posted November 6, 2018 Author Posted November 6, 2018 (edited) Thanks for clearing this up Luke. Can you please tell me where can I find the database Edited November 6, 2018 by ashwin15
ashwin15 2 Posted November 13, 2018 Author Posted November 13, 2018 I want to know how can I use emby apis to get live streaming because I do not have emby generated ids
Luke 42237 Posted November 13, 2018 Posted November 13, 2018 Have you explored our api wiki? https://github.com/MediaBrowser/Emby/wiki Thanks. 1
ashwin15 2 Posted November 15, 2018 Author Posted November 15, 2018 Yes I did but I am not sure how can I play live tv with the help of those api(s)
singhbutes 0 Posted November 15, 2018 Posted November 15, 2018 Hi Luke & AshwinThanks for the updates you have shared here. Wiki content is really helpful.
ashwin15 2 Posted November 15, 2018 Author Posted November 15, 2018 @@Luke Yes I am building an hybrid app which uses emby api for live streaming
Luke 42237 Posted November 15, 2018 Posted November 15, 2018 Can you tell us how far you have gotten into video streaming so far?
ashwin15 2 Posted November 15, 2018 Author Posted November 15, 2018 (edited) I have authenticated users using API key authentication and able to get programs, channels of connected user. But as of now the user id which I have used have schedule direct and hd home run already configured through browser. I do not want users to go out of app to do anything. According to app scenario users will add their pincode through the app only and then they will be able to see tvguide within the app and live streaming of programs will also be available within the app. This link - https://github.com/MediaBrowser/emby-web-mobile is provided in documentation of emby for web client development but it is not working. Please let me know if there is any way I can connect schedule direct and hd home device within the app and how can I live stream programs within the app. Edited November 15, 2018 by ashwin15
Luke 42237 Posted November 15, 2018 Posted November 15, 2018 Please let me know if there is any way I can connect schedule direct and hd home device within the app No, that is done within the server dashboard, not the individual apps.
Luke 42237 Posted November 15, 2018 Posted November 15, 2018 how can I live stream programs within the app. Did you look at the video streaming portion of the wiki?
ashwin15 2 Posted November 16, 2018 Author Posted November 16, 2018 (edited) Yes I did, what I get is that I have to send an UDP message to get an Id and that Id will be used here /Video/{Id}/stream for video streaming. Right? If it's not the case then what does this id mean and how can I play a channels using video streaming api. Edited November 16, 2018 by ashwin15
ashwin15 2 Posted November 19, 2018 Author Posted November 19, 2018 Hello Luke, Thanks for helping out. I am just going through emby code looking for translation id table so that I can use those id(s) in my application. Can you please tell me where I can find translation table and how it is remapped.
