jlparra 1 Posted October 26, 2018 Posted October 26, 2018 Hi, i'm from Chile (and for that, sorry for my english). Recently I update mi chrome mobile to v70 (Samsung s7 Edge), and the OSD controls position go to the top of the frame... I test my web app install (Freenas) in other phones with Anroid 8.0 and realize that the problem it's just chrome v70, at least in Android 8.0. I Attach some pics... it's weird ah?.... It's there some css to modify for fix it?... i tried to debug the scripts with chrome DevTools using remote control to my phone, but can't figured it the problem.... Thanks in advance for the help!
Luke 42242 Posted October 26, 2018 Posted October 26, 2018 Strange. I do not see this. Are you running the latest version of emby server? If you are not on 3.5.3 then please update to the latest version. Thanks. 1
Solution jlparra 1 Posted October 26, 2018 Author Solution Posted October 26, 2018 Perfect, with the update the problem is solved... I think that the "scrolling" solution also correct my problem. one more thing... for Freenas the Emby plugin version is very old... just for keep in mind. Thanks! 1
