fxwegr 6 Posted October 25, 2018 Posted October 25, 2018 I am using TV live together with the emby tvheadend plugin. The TV channels work fine. But the TV radio channels are not played. The radio channels are correctly tagged with the "Other" tag. In the tvheadend settings channels taged with 'Other' is set to radio. What is wrong? My configuration: Ubuntu 18.04 LTS TVheadend server: HTS Tvheadend 4.3-1480~gddfbf1488 Emby Server: 3.5.3.0 Emby Tvheadend plugin: 1.3.9.0 Log.html
Gerrit507 24 Posted October 26, 2018 Posted October 26, 2018 I can only confirm this issue. 2018-10-26 17:58:39.048 Error HttpServer: Error processing request *** Error Report *** Version: 3.6.0.57 Command line: /system/EmbyServer.dll -programdata /config -ffmpeg /bin/ffmpeg -ffprobe /bin/ffprobe -restartexitcode 3 Operating system: Unix 4.15.0.34 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 4 Program data path: /config Application directory: /system System.NullReferenceException: Object reference not set to an instance of an object. Source: Emby.Server.MediaEncoding TargetSite: System.String GetProbeSizeArgument(System.String) at Emby.Server.MediaEncoding.Encoder.EncodingHelper.GetProbeSizeArgument(String inputPath) at Emby.Server.MediaEncoding.Encoder.EncodingHelper.GetInputModifier(EncodingJobInfo state, EncodingOptions encodingOptions) at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.GetCommandLineArguments(String outputPath, EncodingOptions encodingOptions, StreamState state, Boolean isEncoding) at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetOutputFilePath(StreamState state, EncodingOptions encodingOptions, String outputFileExtension) at Emby.Server.MediaEncoding.Api.BaseStreamingService.GetState(StreamRequest request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.Hls.DynamicHlsService.GetMasterPlaylistInternal(StreamRequest request, String method) at Emby.Server.MediaEncoding.Api.UniversalAudioService.GetUniversalStream(GetUniversalAudioStream request, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceExecGeneral.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) It seems that the affected part of the code isn't open-source anymore so I can't really debug it...
pünktchen 1411 Posted October 26, 2018 Posted October 26, 2018 @@Gerrit507 i think that's a long standing bug in Emby. Just set the radio channels in the plugin code to type "TV".
fxwegr 6 Posted October 26, 2018 Author Posted October 26, 2018 What do you mean exactly by this sentence: "Just set the radio channels in the plugin code to type "TV". "
pünktchen 1411 Posted October 26, 2018 Posted October 26, 2018 What do you mean exactly by this sentence: "Just set the radio channels in the plugin code to type "TV". "It was dedicated to the plugin developer not to you as a user.
Tolotos 61 Posted October 27, 2018 Posted October 27, 2018 There is a long time issue (users tell it bug, emby devs feature) not to play radio channels because they don‘t have a video stream.
fxwegr 6 Posted October 27, 2018 Author Posted October 27, 2018 Hi Tolotos, I'm not very clear what you mean with "because they don‘t have a video stream". I receive my streams (radio and TV) via a Digital Device Cine-S2 V7 tuner from Astra 19.2 satellite using a TVH backend server. With Kodi I can easily play all TV streams and all radio streams. With Emby only the TV streams.Could you please check my attached TVH server and my TVH plugin settings if everything is as expected by emby? Thank you
Gerrit507 24 Posted October 27, 2018 Posted October 27, 2018 Hi Tolotos, I'm not very clear what you mean with "because they don‘t have a video stream". I receive my streams (radio and TV) via a Digital Device Cine-S2 V7 tuner from Astra 19.2 satellite using a TVH backend server. With Kodi I can easily play all TV streams and all radio streams. With Emby only the TV streams. Could you please check my attached TVH server and my TVH plugin settings if everything is as expected by emby? Thank you Es liegt nicht an Deiner Konfiguration. Emby kann zum jetzigen Zeitpunkt einfach keine Radio Sender abspielen, weil es einen Video Stream erwartet und dann einen Fehler wirft. Radiosender haben nunmnal keinen Video Stream.
fxwegr 6 Posted October 27, 2018 Author Posted October 27, 2018 Danke für diese Klarstellung. Das lässt mich die Fehlersuche beenden, und könnte auch bewirken dass andere sie erst garnicht beginnen. Ich werde jetzt versuchen die Radiosender über eine .mru Playlist zu realisieren. Das sollte eigentlich gehen. Many thanks and have a nice day!
Luke 42246 Posted October 27, 2018 Posted October 27, 2018 @@Gerrit507 i think that's a long standing bug in Emby. Just set the radio channels in the plugin code to type "TV". If this works then I will just have the core handle this internally for now. The only difference is that it means you'll get a video player UI when you play, as opposed to the small now playing bar at the bottom.
Gerrit507 24 Posted November 4, 2018 Posted November 4, 2018 Is there a pull request needed or will the core be changed?
tdiguy 99 Posted November 4, 2018 Posted November 4, 2018 It will be changed in the next release. Would be cool if this gets corrected. With the holidays approaching my wife used to use the radio stations on the tv a lot for christmas music and such.
Luke 42246 Posted November 4, 2018 Posted November 4, 2018 Please try again with the next release of emby server. thanks.
tdiguy 99 Posted November 4, 2018 Posted November 4, 2018 On the bright side, for me the music choice / radio stations work from the computer, just not from my mi boxes. I will give it another go in next server release also.
