Docker hardware transcode issue
Go to solution Solved by mastrmind11,
Hello,
I'm trying to use hardware transcode on a PC with an i3-4010U using docker. I've added the device to my docker-compose file as per the instruction but it doesn't seems to work and seems to use 100% cpu instead. I get the following error in the logs:
[AVHWDeviceContext @ 0x19f2940] No VA display found for device: /dev/dri/renderD128.
Device creation failed: -22.
Failed to set value '/dev/dri/renderD128' for option 'vaapi_device': Invalid argument
I'm using the latest stable docker image. I'm not sure how I can fix this. Should I use vaapi or Intel Quick Sync ? Both doesn't seems to work :(
I've attached the log files.
Cheers
Logs-server-video.txt
Logs-server.txt
Hi, did you add emby to the video group?
Hey Luke,
It was indeed a permission issue. I chmod 777  /dev/dri/renderD128 and VAAPI works now.
Should I use Intel Quick Sync or VAAPI with an intel CPU ? Quick sync doesn't seems to work.
Cheers
  • Solution
mastrmind11
Hey Luke,
Cheers
vaapi.  Linux doesn't support QS
  • Like 1
Thanks ! I will stick with vaapi.
Glad you worked it out.
