EODCrafter 181 Posted April 17, 2019 Author Posted April 17, 2019 Any timeframe for 2.0? Looking forward to it. @@marmei has said End/May
groenator 13 Posted April 17, 2019 Posted April 17, 2019 Sorry for missing out the conversation, but what changes will bring version 2.0?
EODCrafter 181 Posted April 18, 2019 Author Posted April 18, 2019 (edited) Sorry for missing out the conversation, but what changes will bring version 2.0? Pop on over to Discord and see #news Here's Link >>>>> https://discord.gg/KD2jy5V No reason to type everything twice. Edited April 18, 2019 by EODCrafter
Tony B. 38 Posted April 18, 2019 Posted April 18, 2019 I may have a suggestion. xTeve has quit on me a few times in the last few days. Not sure of the reason why. How about a "-p" for "persistent" I am guessing that I should probably look into my old skool Windows days to figure out how to make it a service. Any clues? I have not made a service in a long time in Win.
CBers 7554 Posted April 18, 2019 Posted April 18, 2019 I may have a suggestion. xTeve has quit on me a few times in the last few days. Not sure of the reason why. How about a "-p" for "persistent" I am guessing that I should probably look into my old skool Windows days to figure out how to make it a service. Any clues? I have not made a service in a long time in Win. Use NSSM. 1
EODCrafter 181 Posted April 18, 2019 Author Posted April 18, 2019 (edited) I may have a suggestion. xTeve has quit on me a few times in the last few days. Not sure of the reason why. How about a "-p" for "persistent" I am guessing that I should probably look into my old skool Windows days to figure out how to make it a service. Any clues? I have not made a service in a long time in Win. Task Scheduler Works for me.....Use these Settings xTeVe.bat File CMD /c "C:\xteve.exe -port="8080" -config="C:\xteve"" Make Sure to Delay the Start of Emby due to DLNA Port issue. (Disable autostart of Emby and Make a Task for it as well and delay by 1 Minute) Edited April 18, 2019 by EODCrafter 1
dcol 177 Posted April 18, 2019 Posted April 18, 2019 Task Scheduler has no method, I know of, for persistence. But as a service, you can restart service. Or you can use a program like Service Protector to have the best options to protect a service.
EODCrafter 181 Posted April 18, 2019 Author Posted April 18, 2019 (edited) Task Scheduler has no method, I know of, for persistence. But as a service, you can restart service. Or you can use a program like Service Protector to have the best options to protect a service. I don't know what your saying, but I do know mine has been running for 3 weeks straight from Task Scheduler with no issues.....Perhaps your talking about this?....... Edited April 18, 2019 by EODCrafter
dcol 177 Posted April 18, 2019 Posted April 18, 2019 (edited) Task scheduler does not respawn programs that have stopped. It can only restart an app while it is trying to initially start it. The only way I can think of to achieve this with task scheduler is to try and start it every minute or so and then set it to 'if the task is already running' set to 'do not start a new instance. It is just a coincidence you haven't failed. The proper way to do it is to use a third party guardian program. Edited April 18, 2019 by dcol
EODCrafter 181 Posted April 18, 2019 Author Posted April 18, 2019 Task scheduler does not respawn programs that have stopped. It can only restart an app while it is trying to initially start it. The only way I can think of to achieve this with task scheduler is to try and start it every minute or so and then set it to 'if the task is already running' set to 'do not start a new instance. It is just a coincidence you haven't failed. The proper way to do it is to use a third party guardian program. Amazing Information from someone who said xTeVe is too hard to understand, but I appreciate it.
dcol 177 Posted April 18, 2019 Posted April 18, 2019 xTeVe has a learning curve and can be finicky, thats all. I use it now.
EODCrafter 181 Posted April 19, 2019 Author Posted April 19, 2019 xTeVe has a learning curve and can be finicky, thats all. I use it now. TBH, I really hate Programs that re-spawn themselves like Emby does, but I can see where this would have it's uses (True Server Platform). I doubt I would use Windows for this though....Too Expensive/Too much Overhead. I like to be more in control over what is running or not.
dcol 177 Posted April 19, 2019 Posted April 19, 2019 All comes down to what you know and your resources. For me, Windows is the only choice.
dcol 177 Posted April 22, 2019 Posted April 22, 2019 (edited) Is there a way to change the backup folder when you do a manual backup? Putting it in AppData>Local>temp is bad for me since this folder gets auto cleaned on a schedule. Why isn't it put in xteve>Backup folder like the auto backup does? And on that note, why doesn't the restore goto the Backup folder? Edited April 22, 2019 by dcol
CBers 7554 Posted April 22, 2019 Posted April 22, 2019 Is there a way to change the backup folder when you do a manual backup? Putting it in AppData>Local>temp is bad for me since this folder gets auto cleaned on a schedule. Why isn't it put in xteve>Backup folder like the auto backup does? And on that note, why doesn't the restore goto the Backup folder? I raised this with @@marmei a while back and it was added to v1.42 I believe. Previously, the setting wasn't taking affect. Make sure you're in the latest version of XTeVe.
marmei 37 Posted April 22, 2019 Posted April 22, 2019 Is there a way to change the backup folder when you do a manual backup? Putting it in AppData>Local>temp is bad for me since this folder gets auto cleaned on a schedule. Why isn't it put in xteve>Backup folder like the auto backup does? And on that note, why doesn't the restore goto the Backup folder? The manual backup is saved in temp and downloaded via the browser
Tony B. 38 Posted April 22, 2019 Posted April 22, 2019 Another feature suggestion: Monitored usage of xTeve: Make a simple screen of what IP is using xTeve, how many tuners it's using, anything else you might be able to get from the client server. I really don't want to go over the limit with my IPTV provider. They just ban you immediately. marmei said that the tuner limit is only for HDHR, is that correct?
dcol 177 Posted April 22, 2019 Posted April 22, 2019 The manual backup is saved in temp and downloaded via the browser I think this should also go in xteve\backup
EODCrafter 181 Posted April 23, 2019 Author Posted April 23, 2019 (edited) I think this should also go in xteve\backup It Does....... Also completely Configurable........ { "api": false, "authentication.api": false, "authentication.m3u": false, "authentication.pms": false, "authentication.web": false, "authentication.xml": false, "backup.keep": 5, "backup.path": "/home/steve/xteve/backup/", "buffer": false, "epgSource": "XEPG", "files": { settings.json As far as Manual Backup, This goes where your Browser is configured to Download Files....IE, Mine Goes into my "Download Folder". Edited April 23, 2019 by EODCrafter
EODCrafter 181 Posted April 23, 2019 Author Posted April 23, 2019 Another feature suggestion: Monitored usage of xTeve: Make a simple screen of what IP is using xTeve, how many tuners it's using, anything else you might be able to get from the client server. I really don't want to go over the limit with my IPTV provider. They just ban you immediately. marmei said that the tuner limit is only for HDHR, is that correct? You can Set the allowed amount of Tuners allowed in Emby...Wouldn't this be a better option? Also you define the Number of Tuners in xTeVe when you set it up.
Tony B. 38 Posted April 23, 2019 Posted April 23, 2019 You can Set the allowed amount of Tuners allowed in Emby...Wouldn't this be a better option? Also you define the Number of Tuners in xTeVe when you set it up. Since I have to use Plex to record TV and Emby to watch Live TV (recordings are really messed up in Emby right now and they are working on it), it's imperative that this xTeve function works as intended.
Carlo 4561 Posted April 23, 2019 Posted April 23, 2019 The problem is that xTeVe can merge multiple provider files. Provider 1 could support 5 streams Provider 2 could support only 1 stream Now feed this file into Emby and what do you set this setting to? 1
dcol 177 Posted April 23, 2019 Posted April 23, 2019 (edited) It Does....... Also completely Configurable........ { "api": false, "authentication.api": false, "authentication.m3u": false, "authentication.pms": false, "authentication.web": false, "authentication.xml": false, "backup.keep": 5, "backup.path": "/home/steve/xteve/backup/", "buffer": false, "epgSource": "XEPG", "files": { settings.json As far as Manual Backup, This goes where your Browser is configured to Download Files....IE, Mine Goes into my "Download Folder". I was referring to manual backups. I know where the scheduled ones go. And as for your default path, not applicable to Windows. Here is how mine is set and the manual backups do not go there. Edited April 23, 2019 by dcol
EODCrafter 181 Posted April 23, 2019 Author Posted April 23, 2019 (edited) I was referring to manual backups. I know where the scheduled ones go. And as for your default path, not applicable to Windows. Here is how mine is set and the manual backups do not go there. Must Depend on the Browser then...In Windows mine still went to C:\Users\me\Downloads..... Edited April 23, 2019 by EODCrafter
Tony B. 38 Posted April 23, 2019 Posted April 23, 2019 The problem is that xTeVe can merge multiple provider files. Provider 1 could support 5 streams Provider 2 could support only 1 stream Now feed this file into Emby and what do you set this setting to? Marmei already said to have multiple instances for different providers. Then set the limit per instance. You can look about three weeks ago for the answer in this thread
