Carlo 4561 Posted March 22, 2019 Posted March 22, 2019 (edited) Nothing built in that I know of. edit: just chatted with marmei about this but he came in and answered so it's covered. Edited March 22, 2019 by cayars
marmei 37 Posted March 22, 2019 Posted March 22, 2019 Is there any way to bind xTeVe to a particular IP/NIC? I want to install on a server with 2 NIC's. One connected to my LAN and the other to the internet. I can't change the metrics or it will affect other software. I tried ForceBindIP, but xTeVe still starts to the wrong interface. I know you can change the port. Any way to change the binding? xTeVe uses the network stack of the operating system and thus all IP addresses, just like your browser. In the Browser you do not set also, which IP address to be used. xTeVe displays only the first IP address, but is accessible via all. With IPv6 it is also normal that a network card has several IP addresses, it simply makes no sense to display all IP addresses. xTeVe also remembers if it is retrieved via a domain and then adapts all URLs with the domain name. 1
dcol 177 Posted March 22, 2019 Posted March 22, 2019 xTeVe uses the network stack of the operating system and thus all IP addresses, just like your browser. In the Browser you do not set also, which IP address to be used. xTeVe displays only the first IP address, but is accessible via all. With IPv6 it is also normal that a network card has several IP addresses, it simply makes no sense to display all IP addresses. xTeVe also remembers if it is retrieved via a domain and then adapts all URLs with the domain name. Ok, I just assumed since xTeVe diplays the wrong IP and I couldn't access it via web browser, that I needed to do something extra. I will work on it and see if I can access it. Thanks for the quick response
dcol 177 Posted March 22, 2019 Posted March 22, 2019 Got it, had to open up 34400 on the firewall. Thanks
Senna 368 Posted March 22, 2019 Posted March 22, 2019 DUH, shoulda remembered that. I will rethink my strategy so I don't use URL's I always advise NEVER to use Live URL's for the m3u used in any Media software package. It could mess up configuration done for your channels, like EPG assignment, channel names, channel logo's, channel groups etc when you (or the Media software package) refreshes that URL when your IPTV provider has changed TAGS for mentioned items in m3u. In DVBLink/TVMosaic/Emby, I always use local m3u's, so that m3u changes of my IPTV provider doesn't affect my setup, regarding EPG assignment, channel names, channel logo's, channel groups etc.
dcol 177 Posted March 22, 2019 Posted March 22, 2019 I realized this and am now using the URL's only in xTeVe and then using the xTeVe m3u/xml with my Emby servers and Perfect Player. Time consuming to get it all right, but worth it in the end. The constant adding and deleting of channels, mostly sporting events, from the IPTV providers was driving me bonkers. xTeve can filter out most of what I don't want to see. 1
marmei 37 Posted March 22, 2019 Posted March 22, 2019 I always advise NEVER to use Live URL's for the m3u used in any Media software package. It could mess up configuration done for your channels, like EPG assignment, channel names, channel logo's, channel groups etc when you (or the Media software package) refreshes that URL when your IPTV provider has changed TAGS for mentioned items in m3u. In DVBLink/TVMosaic/Emby, I always use local m3u's, so that m3u changes of my IPTV provider doesn't affect my setup, regarding EPG assignment, channel names, channel logo's, channel groups etc. there are providers that have unique ID for each stream in the M3U. If an IPTV client also supports this function, the provider can change the name of the channel or all other parameters without breaking the mapping. xTeVe supports this feature. https://cdn.discordapp.com/attachments/484099914574462977/525051040739885077/cuid.mp4
dcol 177 Posted March 22, 2019 Posted March 22, 2019 Seems on one computer 2 providers are clashing and mixing up ownership of channels. Same two providers in another computer running xTeVe gets all the channels correctly. Is there some clue as how I can fix this? Is it an ordering issue? When I added in the second provider it took over some of the channels and then has a bunch of missing ones. Using the same filters on both computers. I like xTeVe but it is really touchy sometimes.
groenator 13 Posted March 23, 2019 Posted March 23, 2019 (edited) Hi, Totally different subject. Since yesterday emby and xteve are acting wired, in a sense of tunner not being available when I play iptv via emby using xteve as a proxy. At the beginning I thought xteve app might be down, I took the xteve m3u list and play it on my other iptv app. It worked as expected, all feeds were up. The only way I found to fix the issue is by restarting the emby container. Does any one having the same issue or encounter similar issues in the past? It used to work without problems, until yesterday night. Edited March 23, 2019 by groenator
Carlo 4561 Posted March 23, 2019 Posted March 23, 2019 Did you xTeVe update from 1.4.2 to 1.4.3 by any chance? Is Stream buffering turned on in xTeVe by any chance?
groenator 13 Posted March 24, 2019 Posted March 24, 2019 (edited) Stream buffering is not on. I haven't checked the version, I think I'm still on the old one (1.4.1), I'll check when I get home. Thanks! Edited March 24, 2019 by groenator
EODCrafter 181 Posted March 24, 2019 Author Posted March 24, 2019 (edited) Did you xTeVe update from 1.4.2 to 1.4.3 by any chance? Is Stream buffering turned on in xTeVe by any chance? Stream Buffering will have 0 effect on M3U Tuner. Edited March 25, 2019 by EODCrafter
groenator 13 Posted March 24, 2019 Posted March 24, 2019 (edited) I am using the latest version of xteve. Since I created the thread it seems that the issue didn't re-occur again. I will keep watching until it does. It only happens two times. Thanks for helping! Edited March 24, 2019 by groenator
dcol 177 Posted March 24, 2019 Posted March 24, 2019 Where are the release notes for xTeVe? What has changed with version 1.4.3?
groenator 13 Posted March 24, 2019 Posted March 24, 2019 good question, on plex forums I only found notes related to 1.4.0. Nothing about 1.4.3 release.
EODCrafter 181 Posted March 25, 2019 Author Posted March 25, 2019 (edited) good question, on plex forums I only found notes related to 1.4.0. Nothing about 1.4.3 release. Join our Discord group...Were FREE, free...free..free..free; if that costs to much were also free....xTeVe Edited March 25, 2019 by EODCrafter
EODCrafter 181 Posted March 25, 2019 Author Posted March 25, 2019 (edited) I am using the latest version of xteve. Since I created the thread it seems that the issue didn't re-occur again. I will keep watching until it does. It only happens two times. Thanks for helping! Excuse me? you did not create this thread nor did you invent the internet (older people will get it ) Edited March 25, 2019 by EODCrafter
Carlo 4561 Posted March 25, 2019 Posted March 25, 2019 (edited) Stream Buffering will have 0 effect on M3U Tuner. EDIT: My bad. Didn't notice the "M3U Tuner" above. Everything said was geared to HDHomeRun emulation mode not M3U. Also edited message a bit to get at what I was really getting at without the technical jargon. Sorry for the misinformation posted. Not a lot of information written in one place to understand how it all works so you have to piece info together from here and there. Original message: Except for instead of of just handing back the links exactly as if you didn't use xTeVe, it instead changes the links to go through xTeVe which then runs the streams through ffmpeg xTeVe to buffer them which hasn't yet worked correctly in Plex or Emby up to 1.4.3 and why it's still experimental. This will mean in Emby all streams are running through ffmpeg at a buffer at least 2 times. It actually has a great affect on how things work (or don't). Also keep in mind you could have been running xTeVe in a virtual machine or very lowend or over worked computer and it didn't previously matter much as the only slow down is in managing links. Once buffering is turned on this "machines" needs a lot more power and CPU to run ffmpeg for each stream being delivered. Edited March 25, 2019 by cayars
EODCrafter 181 Posted March 25, 2019 Author Posted March 25, 2019 (edited) Except for instead of of just handing back the links exactly as if you didn't use xTeVe, it instead changes the links to go through xTeVe which then runs the streams through ffmpeg to buffer them which hasn't yet worked correctly in Plex or Emby up to 1.4.3 and why it's still experimental. This will mean in Emby all streams are running through ffmpeg at least 2 times. It actually has a great affect on how things work (or don't). Also keep in mind you could have been running xTeVe in a virtual machine or very lowend or over worked computer and it didn't previously matter much as the only slow down is in managing links. Once buffering is turned on this "machines" needs a lot more power and CPU to run ffmpeg for each stream being delivered. Where did you get this information? That is not true at all for a M3U Tuner. Buffer only effects Streams in Emby if they are set up as HD Homerun Tuner. I think your going way off topic here, This thread is about using xTeVe with Emby M3U Tuner, not HD Homerun Tuner. Edited March 25, 2019 by EODCrafter 1
marmei 37 Posted March 25, 2019 Posted March 25, 2019 Except for instead of of just handing back the links exactly as if you didn't use xTeVe, it instead changes the links to go through xTeVe which then runs the streams through ffmpeg to buffer them which hasn't yet worked correctly in Plex or Emby up to 1.4.3 and why it's still experimental. This will mean in Emby all streams are running through ffmpeg at least 2 times. It actually has a great affect on how things work (or don't). Also keep in mind you could have been running xTeVe in a virtual machine or very lowend or over worked computer and it didn't previously matter much as the only slow down is in managing links. Once buffering is turned on this "machines" needs a lot more power and CPU to run ffmpeg for each stream being delivered. Unfortunately, that's all wrong. If you use xTeVe as M3U tuner, xTeVe is not involved in streaming. The buffer function is only available if you are using xTeVe as the HDHomeRun tuner. The buffer also does not use FFMPEG or the like. The stream is also not transcoded. The CPU load is minimally higher, xTeVe needs about 2MB RAM for buffering. 2
Carlo 4561 Posted March 25, 2019 Posted March 25, 2019 Sorry, understand how what I said is confusing (and wrong). Typed it late. I edited it with strike outs to make it more clear what I was getting at. In essence the streams need to run through xTeVe if using the buffer functionality which is duplicated functionality of what Emby already does internally. Emby already takes to long to tune to channels so any additional middleware that does any additional processing to the stream in any manner that isn't needed is going to slow this process down further and make diagnosing an issue even harder as there are more layers involved (not really a problem just an observation). In Plex using the HDHomeRun emulation is needed more so then in Emby as Plex doesn't support M3U streams but only TS. In Emby we can add multiple tuners which can be HDHomeRun and/or M3Us but more importantly can add multiple EPGs. Correct me if I'm wrong but there doesn't seem to be a big difference in using xTeVe as a HDHomeRun tuner or M3U tuner with Emby except for weather Emby runs through xTeVe or just uses the streams directly. Missing anything? Admittedly, I've had to stop using xTeVe myself as the channel number changes were driving me crazy in Emby due to the automapping in Emby using channel numbers and not just station ID/names. I've been trying to participate in discord to learn more, make suggestions and gather ideas how to incorporate it better with Emby in general. marmei just yesterday spent some time in discord yesterday giving me/us additional tips on using CUID to "lock" channels numbers, etc which is a help. Thank you both for the clarification which I think was very helpful! Carlo
dcol 177 Posted March 25, 2019 Posted March 25, 2019 Join our Discord group...Were FREE, free...free..free..free; if that costs to much were also free....xTeVe What a useless reply. Didn't see any release notes there either. And I can't stand discord. Very messy and hard to navigate system. This is the forum I use. So where are the release notes!
CBers 7554 Posted March 25, 2019 Posted March 25, 2019 What a useless reply. Didn't see any release notes there either. And I can't stand discord. Very messy and hard to navigate system. This is the forum I use. So where are the release notes! They're in the #release-notes section of the XTeVe Discord. If you want to obtain further XTeVe support, then Discord is their support channel. 1
dcol 177 Posted March 25, 2019 Posted March 25, 2019 Ok, see it now. Looks like latest release only affect HDHomerun users with the stream option enabled. Man I don't like Discord. Horrible interface. 1
EODCrafter 181 Posted March 25, 2019 Author Posted March 25, 2019 (edited) Ok, see it now. Looks like latest release only affect HDHomerun users with the stream option enabled. Man I don't like Discord. Horrible interface. Yea, Not everyone has Resources like Emby, this is all done voluntarily with no Pay. I'm curious @@dcol, how do you get IPTV to work in Emby without Sorting the channels? Do you just throw 8k channels at Emby and let it randomly sort them? Edited March 30, 2019 by EODCrafter
