kikinjo 294 Posted February 13, 2023 Posted February 13, 2023 11 hours ago, Przemek said: Do You know it's safe to use that editor? How to be sure if they don't use my channels list when I upload to their server? Read the Terms and conditions.
Spaceboy 2573 Posted February 13, 2023 Posted February 13, 2023 why would you not use iptvboss? all local and worked very well from my experience 2
Przemek 70 Posted February 14, 2023 Posted February 14, 2023 22 hours ago, Spaceboy said: why would you not use iptvboss? all local and worked very well from my experience I don't know that service. I configure Xteve now and combine all EPGs with my chnnels list and add to Emby. For now it works OK.
Przemek 70 Posted February 14, 2023 Posted February 14, 2023 @Spaceboy do You know it's possible to download single EPG xml file from IPTVboss app?
Spaceboy 2573 Posted February 14, 2023 Posted February 14, 2023 10 hours ago, Przemek said: @Spaceboy do You know it's possible to download single EPG xml file from IPTVboss app? not clear on your question. you can add your epg sources (xmltv local or web based), use that provided by iptvboss (for a fee) or generate dummy data. you then assign to your channels, auto or manual as needed you then export single m3u and xmltv files or set them to be refreshed on a schedule
Przemek 70 Posted February 14, 2023 Posted February 14, 2023 I don't understand that app. I just look for some EPG's urls.
musicmate 14 Posted May 30, 2023 Posted May 30, 2023 If anyone here is looking for something more supported than xteve (as it hasn't received any updates for a while now), try out Threadfin, essentially the same thing, just rebranded and actively developed: https://github.com/Threadfin/Threadfin 1 3
EODCrafter 181 Posted May 31, 2023 Author Posted May 31, 2023 (edited) Emby has made xTeVe/ThreadFin Obsolete for my use. Edited May 31, 2023 by EODCrafter added info
sross44 434 Posted May 31, 2023 Posted May 31, 2023 11 hours ago, EODCrafter said: Emby has made xTeVe/ThreadFin Obsolete for my use. Do you have a lot of channels? That's my biggest gripe with Emby's editor. There's really no way of mass editing if you had say 10,000+ channels dumped in to it.
EODCrafter 181 Posted June 1, 2023 Author Posted June 1, 2023 12 hours ago, sross44 said: Do you have a lot of channels? That's my biggest gripe with Emby's editor. There's really no way of mass editing if you had say 10,000+ channels dumped in to it. No, I sort them with IPTV Boss Prior to Emby....too much junk 2
GrimEvil 73 Posted June 2, 2023 Posted June 2, 2023 Some questions Does iptv boss update the channels or delete removed channels etc? can it map more than one stream to channel? Thanks
BillOatman 597 Posted June 2, 2023 Posted June 2, 2023 2 hours ago, grimevil said: Some questions Does iptv boss update the channels or delete removed channels etc? can it map more than one stream to channel? Thanks Its a very full featured editor and much more. Best thing is to take a look.
EODCrafter 181 Posted June 3, 2023 Author Posted June 3, 2023 19 hours ago, grimevil said: Some questions Does iptv boss update the channels or delete removed channels etc? can it map more than one stream to channel? Thanks Join the discord channel and ask them. The author is very engaged.
Spaceboy 2573 Posted June 3, 2023 Posted June 3, 2023 it definitely does the first. don't think it does the second or why you would want it to? i can only assume you have streams with different resolutions mapping to the same channel but there is no function to handle this in emby anyway. you're better off letting emby handle the transcoding to lower resolutions/qualities
BillOatman 597 Posted June 3, 2023 Posted June 3, 2023 6 hours ago, Spaceboy said: it definitely does the first. don't think it does the second or why you would want it to? i can only assume you have streams with different resolutions mapping to the same channel but there is no function to handle this in emby anyway. you're better off letting emby handle the transcoding to lower resolutions/qualities Multiple providers for backup. 2
Spaceboy 2573 Posted June 3, 2023 Posted June 3, 2023 17 minutes ago, BillOatman said: Multiple providers for backup. yeah good call. actually i guess i would like that in emby but it does need to be supported in emby for any m3u before we can look to find a iptv editor that supports it too. funny thing is (not funny at all actually) the code for emby to do all of this without any third party program support was written 3 years ago but remains unreleased... one day 2
BillOatman 597 Posted June 4, 2023 Posted June 4, 2023 19 hours ago, Spaceboy said: yeah good call. actually i guess i would like that in emby but it does need to be supported in emby for any m3u before we can look to find a iptv editor that supports it too. funny thing is (not funny at all actually) the code for emby to do all of this without any third party program support was written 3 years ago but remains unreleased... one day Wa ... Wa ... What?!?
GrimEvil 73 Posted June 4, 2023 Posted June 4, 2023 On 03/06/2023 at 14:54, Spaceboy said: it definitely does the first. don't think it does the second or why you would want it to? i can only assume you have streams with different resolutions mapping to the same channel but there is no function to handle this in emby anyway. you're better off letting emby handle the transcoding to lower resolutions/qualities So I can use it the same as normal duel tunner, so different people can watch different channels as most providers only allow 1 stream. 1
EODCrafter 181 Posted June 5, 2023 Author Posted June 5, 2023 9 hours ago, grimevil said: so different people can watch different channels as most providers only allow 1 stream. No.
sross44 434 Posted June 5, 2023 Posted June 5, 2023 It’s still limited by the number of streams your provider allows. Each “tuner” counts as one stream.
pdclark 11 Posted June 20, 2023 Posted June 20, 2023 The only reason I'm considering addding threadfin is for backup channels. Quite often Emby fails to record or only records a few minutes of a show and errors out (logs say no stream) It would be nice to have Emby try to open the stream on a separate (but same content) channel after failing. threadfin allows for 3 backups. 1
Spaceboy 2573 Posted June 20, 2023 Posted June 20, 2023 threadfin does sound interesting but my channels are reliable enough that i'm happy to wait for emby to build this in. combination of OTA and a very reliable iptv
neik 874 Posted June 20, 2023 Posted June 20, 2023 41 minutes ago, Spaceboy said: emby to build this in. When you're saying that, are you referring to TVnext integration? 1
Spaceboy 2573 Posted June 20, 2023 Posted June 20, 2023 1 hour ago, neik said: When you're saying that, are you referring to TVnext integration? yes
