Damien_ 30 Posted August 29, 2022 Posted August 29, 2022 4 hours ago, CharlieMurphy said: I don't see them as the same thing even though they overlap features. xTeVe as an HDHR emulator for Plex,without using a buffer, is good. xTeVe as a proxy with the three options of buffers is unreliable. xTeVe as channel management is a nightmare. IPTVBoss as a channel and guide manager is outstanding. I do recommend it even if you don't use their guide data. Make sure to tick the option for Emby. yea I dont think they are. Xteve's primary function is an network tuner/emulator. Secondary is it gives you some functionality to edit your XML guide (as you mentioned it's not great). I believe IPTVboss is similar to m3u-editor to edit your XML guide. I could be wrong as I dont know IPTV Boss well but that's my understanding.
horstepipe 423 Posted October 14, 2022 Posted October 14, 2022 Hello has anybody an idea why xteve+emby works flawlessly on my Ubuntu 20.04 server when xteve is integrated via the external server ip, but it does not work when it is being integrated via http://127.0.0.1:26686/m3u/xteve.m3u . When I start a stream in Emby xteve sees it: 2022-10-14 10:47:43 [xTeVe] Channel Name: ProSieben 2022-10-14 10:47:43 [xTeVe] Client User-Agent: VLC/3.0.0-git LibVLC/3.0.0-git 2022-10-14 10:47:43 [xTeVe] Streaming Status: Playlist: teleboy - Tuner: 1 / 10 2022-10-14 10:47:43 [xTeVe] FFMPEG path: /usr/bin/ffmpeg 2022-10-14 10:47:43 [xTeVe] Streaming URL: http://teleboy-api:5000/api/tby/live/354.m3u8 2022-10-14 10:47:43 [xTeVe] FFMPEG: Processing data 2022-10-14 10:47:43 [xTeVe] Streaming Status: Receive data from FFMPEG 2022-10-14 10:47:57 [xTeVe] Streaming Status: Buffering data from FFMPEG 2022-10-14 10:48:13 [xTeVe] Streaming Status: Client has terminated the connection 2022-10-14 10:48:13 [xTeVe] Streaming Status: Channel: ProSieben (Clients: 0) 2022-10-14 10:48:14 [xTeVe] Streaming Status: Channel: ProSieben - No client is using this channel anymore. Streaming Server connection has ended 2022-10-14 10:48:14 [xTeVe] Streaming Status: Playlist: teleboy - Tuner: 0 / 10 Emby server drops these errors: 2022-10-14 10:48:13.034 Error HttpClient: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out 2022-10-14 10:48:13.040 Error LiveTV: Error in GetChannelStreamWithDirectStreamProvider *** Error Report *** Version: 4.7.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-126-generic (buildd@lcy02-amd64-072) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken, Int32 recursion) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.Open(CancellationToken openCancellationToken) at MediaBrowser.Controller.LiveTv.BaseTunerHost.GetChannelStream(TunerHostInfo tuner, BaseItem dbChannnel, String tunerChannelId, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. Source: System.Net.Http TargetSite: Void HandleFailure(System.Exception, Boolean, System.Net.Http.HttpResponseMessage, System.Threading.CancellationTokenSource, System.Threading.CancellationToken, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.TimeoutException: The operation was canceled. Source: TargetSite: InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite: 2022-10-14 10:48:13.043 Error MediaSourceManager: Error opening live stream *** Error Report *** Version: 4.7.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-126-generic (buildd@lcy02-amd64-072) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. Source: System.Net.Http TargetSite: Void HandleFailure(System.Exception, Boolean, System.Net.Http.HttpResponseMessage, System.Threading.CancellationTokenSource, System.Threading.CancellationToken, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.TimeoutException: The operation was canceled. Source: TargetSite: InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite: 2022-10-14 10:48:13.047 Error Server: Error processing request *** Error Report *** Version: 4.7.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-126-generic (buildd@lcy02-amd64-072) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStream(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.OpenMediaSource(OpenMediaSource request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(GetPostedPlaybackInfo request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetPostedPlaybackInfo request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. Source: System.Net.Http TargetSite: Void HandleFailure(System.Exception, Boolean, System.Net.Http.HttpResponseMessage, System.Threading.CancellationTokenSource, System.Threading.CancellationToken, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.TimeoutException: The operation was canceled. Source: TargetSite: InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite: I'm a little clouless where the problem is.
EODCrafter 181 Posted October 14, 2022 Author Posted October 14, 2022 (edited) 6 minutes ago, horstepipe said: Hello has anybody an idea why xteve+emby works flawlessly on my Ubuntu 20.04 server when xteve is integrated via the external server ip, but it does not work when it is being integrated via http://127.0.0.1:26686/m3u/xteve.m3u . When I start a stream in Emby xteve sees it: 2022-10-14 10:47:43 [xTeVe] Channel Name: ProSieben 2022-10-14 10:47:43 [xTeVe] Client User-Agent: VLC/3.0.0-git LibVLC/3.0.0-git 2022-10-14 10:47:43 [xTeVe] Streaming Status: Playlist: teleboy - Tuner: 1 / 10 2022-10-14 10:47:43 [xTeVe] FFMPEG path: /usr/bin/ffmpeg 2022-10-14 10:47:43 [xTeVe] Streaming URL: http://teleboy-api:5000/api/tby/live/354.m3u8 2022-10-14 10:47:43 [xTeVe] FFMPEG: Processing data 2022-10-14 10:47:43 [xTeVe] Streaming Status: Receive data from FFMPEG 2022-10-14 10:47:57 [xTeVe] Streaming Status: Buffering data from FFMPEG 2022-10-14 10:48:13 [xTeVe] Streaming Status: Client has terminated the connection 2022-10-14 10:48:13 [xTeVe] Streaming Status: Channel: ProSieben (Clients: 0) 2022-10-14 10:48:14 [xTeVe] Streaming Status: Channel: ProSieben - No client is using this channel anymore. Streaming Server connection has ended 2022-10-14 10:48:14 [xTeVe] Streaming Status: Playlist: teleboy - Tuner: 0 / 10 Emby server drops these errors: 2022-10-14 10:48:13.034 Error HttpClient: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out 2022-10-14 10:48:13.040 Error LiveTV: Error in GetChannelStreamWithDirectStreamProvider *** Error Report *** Version: 4.7.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-126-generic (buildd@lcy02-amd64-072) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.OpenStream(IDisposable connectionContext, MediaSourceInfo mediaSource, String url, MediaProtocol protocol, CancellationToken cancellationToken, Int32 recursion) at Emby.LiveTV.TunerHosts.SharedHttpPipelineSource.Open(CancellationToken openCancellationToken) at MediaBrowser.Controller.LiveTv.BaseTunerHost.GetChannelStream(TunerHostInfo tuner, BaseItem dbChannnel, String tunerChannelId, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. Source: System.Net.Http TargetSite: Void HandleFailure(System.Exception, Boolean, System.Net.Http.HttpResponseMessage, System.Threading.CancellationTokenSource, System.Threading.CancellationToken, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.TimeoutException: The operation was canceled. Source: TargetSite: InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite: 2022-10-14 10:48:13.043 Error MediaSourceManager: Error opening live stream *** Error Report *** Version: 4.7.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-126-generic (buildd@lcy02-amd64-072) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. Source: System.Net.Http TargetSite: Void HandleFailure(System.Exception, Boolean, System.Net.Http.HttpResponseMessage, System.Threading.CancellationTokenSource, System.Threading.CancellationToken, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.TimeoutException: The operation was canceled. Source: TargetSite: InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite: 2022-10-14 10:48:13.047 Error Server: Error processing request *** Error Report *** Version: 4.7.8.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Linux version 5.4.0-126-generic (buildd@lcy02-amd64-072) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #142-Ubuntu SMP Fri Aug 26 12:12:57 UTC 2 Framework: .NET 6.0.8 OS/Process: x64/x64 Runtime: opt/emby-server/system/System.Private.CoreLib.dll Processor count: 8 Data path: /var/lib/emby Application path: /opt/emby-server/system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Connection to http://127.0.0.1:26686/stream/452b6ab61f29f7717809ab1f9983d849 timed out ---> System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. ---> System.TimeoutException: The operation was canceled. ---> System.Threading.Tasks.TaskCanceledException: The operation was canceled. ---> System.IO.IOException: Unable to read data from the transport connection: Operation canceled. ---> System.Net.Sockets.SocketException (125): Operation canceled --- End of inner exception stack trace --- at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) --- End of inner exception stack trace --- at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) --- End of inner exception stack trace --- --- End of inner exception stack trace --- at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) --- End of inner exception stack trace --- at Emby.LiveTV.EmbyTV.GetChannelStreamWithDirectStreamProvider(BaseItem dbChannel, String providerChannelId, String streamId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.GetChannelStream(String id, String mediaSourceId, List`1 currentLiveStreams, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal2(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStreamInternal(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.Implementations.Library.MediaSourceManager.OpenLiveStream(LiveStreamRequest request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.OpenMediaSource(OpenMediaSource request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.GetPlaybackInfo(GetPostedPlaybackInfo request, CancellationToken cancellationToken) at Emby.Server.MediaEncoding.Api.MediaInfoService.Post(GetPostedPlaybackInfo request) at Emby.Server.Implementations.Services.ServiceController.GetTaskResult(Task task) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, RestPath restPath, String responseContentType, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IRequest httpReq, ReadOnlyMemory`1 urlString, ReadOnlyMemory`1 localPath, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() InnerException: System.Threading.Tasks.TaskCanceledException: The request was canceled due to the configured HttpClient.Timeout of 30 seconds elapsing. Source: System.Net.Http TargetSite: Void HandleFailure(System.Exception, Boolean, System.Net.Http.HttpResponseMessage, System.Threading.CancellationTokenSource, System.Threading.CancellationToken, System.Threading.CancellationTokenSource) at System.Net.Http.HttpClient.HandleFailure(Exception e, Boolean telemetryStarted, HttpResponseMessage response, CancellationTokenSource cts, CancellationToken cancellationToken, CancellationTokenSource pendingRequestsCts) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) InnerException: System.TimeoutException: The operation was canceled. Source: TargetSite: InnerException: System.Threading.Tasks.TaskCanceledException: The operation was canceled. Source: System.Net.Http TargetSite: Void MoveNext() at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpConnectionPool.SendWithVersionDetectionAndRetryAsync(HttpRequestMessage request, Boolean async, Boolean doRequestAuth, CancellationToken cancellationToken) at System.Net.Http.DiagnosticsHandler.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.RedirectHandler.SendAsync(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) at System.Net.Http.HttpClient.<SendAsync>g__Core|83_0(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationTokenSource cts, Boolean disposeCts, CancellationTokenSource pendingRequestsCts, CancellationToken originalCancellationToken) InnerException: System.IO.IOException: Unable to read data from the transport connection: Operation canceled. Source: System.Net.Sockets TargetSite: Void ThrowException(System.Net.Sockets.SocketError, System.Threading.CancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.ThrowException(SocketError error, CancellationToken cancellationToken) at System.Net.Sockets.Socket.AwaitableSocketAsyncEventArgs.System.Threading.Tasks.Sources.IValueTaskSource<System.Int32>.GetResult(Int16 token) at System.Net.Http.HttpConnection.InitialFillAsync(Boolean async) at System.Net.Http.HttpConnection.SendAsyncCore(HttpRequestMessage request, Boolean async, CancellationToken cancellationToken) InnerException: System.Net.Sockets.SocketException: Operation canceled Source: TargetSite: I'm a little clouless where the problem is. I assume you manually changed the Port? Default is 34400, I beleive. Edited October 14, 2022 by EODCrafter
horstepipe 423 Posted October 14, 2022 Posted October 14, 2022 3 minutes ago, EODCrafter said: I assume you manually changed the Port? Default is 34400, I beleive. is the internal port different to the external one? I didn't change any port settings in xteve.
EODCrafter 181 Posted October 14, 2022 Author Posted October 14, 2022 (edited) 4 minutes ago, horstepipe said: is the internal port different to the external one? I didn't change any port settings in xteve. No, just a thought. I'm no network expert. Strange though as the default port in xTeVe is 34400, so something changed it. Edited October 14, 2022 by EODCrafter
horstepipe 423 Posted October 14, 2022 Posted October 14, 2022 2 minutes ago, EODCrafter said: No, just a thought. I'm no network expert. Strange though as the default port in xTeVe is 34400, so something changed it. maybe just on docker? I'm using the standard version.
EODCrafter 181 Posted October 14, 2022 Author Posted October 14, 2022 (edited) 4 minutes ago, horstepipe said: maybe just on docker? I'm using the standard version. Docker uses an isolated network. Is the Docker in "Host" mode? With the xTeVe approved Docker, DNSForge or Alturismo Docker, They both use 34400. Edited October 14, 2022 by EODCrafter 1
EODCrafter 181 Posted October 14, 2022 Author Posted October 14, 2022 (edited) Here is LeeD's Settings.... Edited October 14, 2022 by EODCrafter 1
EODCrafter 181 Posted October 14, 2022 Author Posted October 14, 2022 Here's the Link to Lee's Docker.....https://hub.docker.com/r/dnsforge/xteve 1
horstepipe 423 Posted October 14, 2022 Posted October 14, 2022 8 minutes ago, EODCrafter said: Here's the Link to Lee's Docker.....https://hub.docker.com/r/dnsforge/xteve thank you, but I was trying to say that I do NOT use docker, sorry. But nevermind, after some restarts it is working as expected now. Thanks for your time!
EODCrafter 181 Posted October 14, 2022 Author Posted October 14, 2022 (edited) 3 minutes ago, horstepipe said: thank you, but I was trying to say that I do NOT use docker, sorry. But nevermind, after some restarts it is working as expected now. Thanks for your time! Your Welcome! Sry for the misunderstanding. Here's the "original" xTeVe Link for REF: https://github.com/xteve-project/xTeVe Edited October 14, 2022 by EODCrafter 1
BillOatman 597 Posted October 17, 2022 Posted October 17, 2022 Looks like someone has picked up the torch for xTeVe and calls it ThreadFin
Damien_ 30 Posted October 17, 2022 Posted October 17, 2022 1 hour ago, BillOatman said: Looks like someone has picked up the torch for xTeVe and calls it ThreadFin Thanks for sharing that. I wonder if it has any features not available on xteve..
Spaceboy 2573 Posted October 17, 2022 Posted October 17, 2022 i've just transitioned from xteve to iptvboss. would definitely recommend, but i still use xteve as a proxy
GWTPqZp6b 50 Posted October 18, 2022 Posted October 18, 2022 What are the primary benefits @Spaceboy?
EODCrafter 181 Posted October 18, 2022 Author Posted October 18, 2022 (edited) 19 hours ago, BillOatman said: Looks like someone has picked up the torch for xTeVe and calls it ThreadFin Looks like a copy/paste of xTeVe. Do they have a support forum? The Dev could of, at least, copied xTeVe's 150 open issues and addressed them. Edited October 18, 2022 by EODCrafter
EODCrafter 181 Posted October 18, 2022 Author Posted October 18, 2022 (edited) 14 hours ago, Spaceboy said: i've just transitioned from xteve to iptvboss. would definitely recommend, but i still use xteve as a proxy IPTVBoss is a true re-write of xTeVe with TONS of features added! Works great! https://iptvboss.pro/ Edited October 18, 2022 by EODCrafter
Spaceboy 2573 Posted October 18, 2022 Posted October 18, 2022 19 hours ago, GWTPqZp6b said: What are the primary benefits @Spaceboy ? its quite a bit more user friendly than xteve. and i say that as someone that happily used xteve for a long time it solved the problem of iptv providers changing channel names for the UK football games and those channels being dropped because they were seen to be new channels. it uses far less ram than xteve
Damien_ 30 Posted October 21, 2022 Posted October 21, 2022 (edited) On 10/18/2022 at 5:24 AM, EODCrafter said: IPTVBoss is a true re-write of xTeVe with TONS of features added! Works great! https://iptvboss.pro/ so iptvboss is an IPTV emulator? I thought it was an editor but I'm not super familiar Edit- Xteve is a network tuner emulator. It has some guide editing ability but it's primary function is to be a network tuner. iptvboss appears to be just an editor, although I'm sure it has much more robust feature set for editing your EPG. Edited October 21, 2022 by meatball 1
EODCrafter 181 Posted October 22, 2022 Author Posted October 22, 2022 (edited) 11 hours ago, meatball said: so iptvboss is an IPTV emulator? I thought it was an editor but I'm not super familiar Edit- Xteve is a network tuner emulator. It has some guide editing ability but it's primary function is to be a network tuner. iptvboss appears to be just an editor, although I'm sure it has much more robust feature set for editing your EPG. I'm not a Techy but I think it can remux like xTeVe. The Dev (Walrusone) said he based Boss directly off xTeVe's shortcomings. As far as emulator.....I don't even think xTeVe could be called that. (I never used OTA or Plex, so I never needed xTeVe for anything other than a EPG Proxy). Best thing to do is go on Boss Discord and ask the Dev, He's very helpful. Edited October 22, 2022 by EODCrafter
EODCrafter 181 Posted October 22, 2022 Author Posted October 22, 2022 (edited) Apparently, you can stack Playlists and Boss can seamlessly switch to next available stream. We have been asking for this feature in Emby for years. @pir8radio Edited October 22, 2022 by EODCrafter 2
EODCrafter 181 Posted October 22, 2022 Author Posted October 22, 2022 (edited) I asked....awaiting answer...... Answer: No....Just a Playlist/EPG Editor....... Edited October 22, 2022 by EODCrafter
sross44 434 Posted February 1, 2023 Posted February 1, 2023 I'm sure this may be in this post SOMEWHERE, but I did a quick glance and didn't find it, so I figured I'd ask real quick. Is there any difference from an Emby perspective if you connect to Xteve when you set up live tv using the M3U or HDHomeRun IP address? Just curious if there is at all... I don't think so, but thought I'd ask what everyone's thoughts are.
pmac 143 Posted February 1, 2023 Posted February 1, 2023 (edited) On 18/10/2022 at 18:20, Spaceboy said: its quite a bit more user friendly than xteve. and i say that as someone that happily used xteve for a long time it solved the problem of iptv providers changing channel names for the UK football games and those channels being dropped because they were seen to be new channels. it uses far less ram than xteve I'm just trying to get live tv working and I've been experimenting with xTeVe and IPTVBoss; when I load my channels into xTeVe, they load in the order they're listed in my M3U, with IPTVBoss, they seem to be in some random order. I've tried tvg-chno="100"..."101"... etc, as well as channel-number="100"...etc, but it seems to just place the channels in its own order no matter what. Manually numbering channels in IPTVBoss will be a huge undertaking, Do you have any suggestions? Edited February 1, 2023 by pmac
CharlieMurphy 93 Posted February 1, 2023 Posted February 1, 2023 What is the function of using xTeVe in your setup? My suggestion is to never use it, unless you need to emulate an HDHR for Plex. You'd get to keep your hair, too. 1
