Damien_ 30 Posted August 2, 2019 Posted August 2, 2019 Version 2.0 Released......https://xteve.de/ Also Source: https://github.com/xteve-project/xTeVe Great news!
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 Need a Linux/Ubuntu Guru: The systemd script on Github/Discord doesn't seem to have instructions for other ports and config files. I desperately need some help. I have been trying different variations of the systemd service script and nothing seems to work. With the release of 2.0, it seems that I can't run it from a cronjob either So! I would love to know who out there can help me with this. Thanks in advance! Tony
EODCrafter 181 Posted August 10, 2019 Author Posted August 10, 2019 (edited) Need a Linux/Ubuntu Guru: The systemd script on Github/Discord doesn't seem to have instructions for other ports and config files. I desperately need some help. I have been trying different variations of the systemd service script and nothing seems to work. With the release of 2.0, it seems that I can't run it from a cronjob either So! I would love to know who out there can help me with this. Thanks in advance! Tony Those guys stay tucked away on Discord I'm afraid https://discordapp.com/channels/465222357754314767/608557636069228546 Source: https://github.com/xteve-project/xTeVe Configuration: https://github.com/x...onfiguration.md Releases: https://github.com/x.../xTeVe/releases Migration from 1.4.4: 1. You make a backup of 1.4.4 (Settings -> Backup) 2. Exit xTeVe 1.4.4 3. Start xTeVe 2.0.0 4. Go through the wizard 5. Restore the configuration of 1.4.4 (Setting -> Restore -> Select backup file) xTeVe Docker Hub https://xteve.dnsforge.net/ Downloads and other useful Info http://xteve.de https://github.com/xteve-project/xTeVe-Documentation/blob/master/en/scripts.md#linux-systemd xteve -port="8080" Edited August 10, 2019 by EODCrafter 1
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 Those guys stay tucked away on Discord I'm afraid https://discordapp.com/channels/465222357754314767/608557636069228546 Nobody has a clue of what is required to run the service on a different port with a separate configuration on the discord site. They don't have Linux experience. That's exactly what they said to me, hence why I brought it here for a larger audience. Marmei is actually the one that said that. So, if the designer of the software has no idea, I guess I'm truly screwed, lol 1
marmei 37 Posted August 10, 2019 Posted August 10, 2019 Nobody has a clue of what is required to run the service on a different port with a separate configuration on the discord site. They don't have Linux experience. That's exactly what they said to me, hence why I brought it here for a larger audience. Marmei is actually the one that said that. So, if the designer of the software has no idea, I guess I'm truly screwed, lol This is an example script to start xTeVe. If that's not enough, just have to deal with systemd. For systemd there is enough information on the internet. Google result (Not tested, but looks good): https://superuser.com/questions/728951/systemd-giving-my-service-multiple-arguments
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 I searched on Google and tried that before I posted my question.. It didn't work. Also tried a shell script, that didn't work. Nothing is working, otherwise, I would have posted the answer instead of the question Everything seems to be terminating with 217/USER. Not sure what that means. It would be great if there was more documentation on the internet about this, or even better if there was a part of the GUI that let us configure the port and configuration file. I digress, you just had a huge release, I'm sure you have your hands full with that. xTeve doesn't seem to be compatible with service files that need parameters. There are other programs that are compatible, but just not xTeve.
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 (edited) I just thought about this. It may be a bug. It used to be able to start it with a cronjob Now, it's impossible to start it unattended Edited August 10, 2019 by Tony B.
marmei 37 Posted August 10, 2019 Posted August 10, 2019 I searched on Google and tried that before I posted my question.. It didn't work. Also tried a shell script, that didn't work. Nothing is working, otherwise, I would have posted the answer instead of the question Everything seems to be terminating with 217/USER. Not sure what that means. It would be great if there was more documentation on the internet about this, or even better if there was a part of the GUI that let us configure the port and configuration file. I digress, you just had a huge release, I'm sure you have your hands full with that. xTeve doesn't seem to be compatible with service files that need parameters. There are other programs that are compatible, but just not xTeve. No matter what does not work for you, xTeVe is not the problem systemd: [Unit] Description=xTeVe Service Wants=network-online.target After=network-online.target [Service] Type=simple ExecStart=/home/marmei/bin/xteve -config=/home/marmei/new/ -port=34401 ExecReload=/usr/bin/killall xteve ExecStop=/usr/bin/killall xteve KillMode=process Restart=always RestartSec=15 User=marmei Group=wheel [Install] WantedBy=multi-user.target
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 (edited) @@marmei I tried that yesterday but used yours instead. Results: ● xteve-bt.service - xTeVe Service Loaded: loaded (/etc/systemd/system/xteve-bt.service; enabled; vendor preset: enabled) Active: activating (auto-restart) (Result: exit-code) since Sat 2019-08-10 13:54:27 MST; 3s ago Process: 77279 ExecStop=/usr/bin/killall xteve (code=exited, status=1/FAILURE) Process: 77277 ExecStart=/home/home/tony/xteve-bt/xteve -config=/home/tony/xteve-bt -port=36660 (code=exited, status=203/EXEC) Main PID: 77277 (code=exited, status=203/EXEC)Aug 10 13:54:27 TZPLCHVTPA-MTA1.tinozplace.com systemd[1]: xteve-bt.service: Unit entered failed state.Aug 10 13:54:27 TZPLCHVTPA-MTA1.tinozplace.com systemd[1]: xteve-bt.service: Failed with result 'exit-code'. Service: [unit]Description=xTeVe ServiceWants=network-online.targetAfter=network-online.target[service]Type=simpleExecStart=/home/home/tony/xteve-bt/xteve -config=/home/tony/xteve-bt -port=36660ExecReload=/usr/bin/killall xteveExecStop=/usr/bin/killall xteveKillMode=processRestart=alwaysRestartSec=15User=tonyGroup=tony[install]WantedBy=multi-user.target Edited August 10, 2019 by Tony B.
marmei 37 Posted August 10, 2019 Posted August 10, 2019 Check if the permissions are correct chmod and chown I do not have any more ideas for Linux either.
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 Check if the permissions are correct chmod and chown I do not have any more ideas for Linux either. -rwxr-xr-x 1 tony tony 9471072 Aug 10 14:01 xteve Dunno. I have tried pretty much everything
Tony B. 38 Posted August 10, 2019 Posted August 10, 2019 Finally figured it out.. Instructions below call this myxteve.service in /etc/systemd/system (Ubuntu), change it to whatever you want myxteve.service: [unit]Description=xTeVe ServiceWants=network-online.targetAfter=network-online.target[service]Type=simpleExecStart=/bin/bash /usr/local/bin/xteve.shExecReload=/usr/bin/killall xteveExecStop=/usr/bin/killall xteveKillMode=processRestart=alwaysRestartSec=15User=tonyGroup=tony[install]WantedBy=multi-user.target Put a script somewhere (I chose /usr/local/bin) with the startup info and make sure to give it execution priv (chmod +x mxteveservice.sh) that looks like this: # /bin/sh/home/tony/xteve-36660/xteve -port="36660" -config="/home/tony/xteve-36660" Change that service file (at the top of the instructions) to reflect where you put this script. systemctl enable myxteve.service systemctl start myxteve.service systemctl status myxteve.service (to see if it's running) You should see: myxteve.service - xTeVe Service Loaded: loaded (/etc/systemd/system/myxteve.service; enabled; vendor preset: enabled) Active: active (running) since Sat 2019-08-10 14:37:50 MST; 1min 3s ago Process: 4724 ExecStop=/usr/bin/killall xteve (code=exited) Main PID: 4730 (bash) Tasks: 13 Memory: 118.3M CPU: 1min 16.294s
kanipek 230 Posted August 14, 2019 Posted August 14, 2019 Well it seems I have finally got xTeVe figured out, setup and what not. I no sooner get this all done and my provider tells me they are shoving me off to a reseller. Not being a wiz with xTeVe I am wondering how this is going to affect xTeVe? - I have the URL to the new M3U, same username, different PW, all else remains the same, channel list, and those links are identical except the tokens. I handle the EPG myself through SD so that remains the same. Can I just drop in the new M3U link and remove the original one and it will be done....? Please as my 11 year old says "Say yes"....
EODCrafter 181 Posted August 14, 2019 Author Posted August 14, 2019 (edited) Well it seems I have finally got xTeVe figured out, setup and what not. I no sooner get this all done and my provider tells me they are shoving me off to a reseller. Not being a wiz with xTeVe I am wondering how this is going to affect xTeVe? - I have the URL to the new M3U, same username, different PW, all else remains the same, channel list, and those links are identical except the tokens. I handle the EPG myself through SD so that remains the same. Can I just drop in the new M3U link and remove the original one and it will be done....? Please as my 11 year old says "Say yes".... Yes! Edited August 14, 2019 by EODCrafter
BillOatman 597 Posted August 14, 2019 Posted August 14, 2019 Well it seems I have finally got xTeVe figured out, setup and what not. I no sooner get this all done and my provider tells me they are shoving me off to a reseller. Not being a wiz with xTeVe I am wondering how this is going to affect xTeVe? - I have the URL to the new M3U, same username, different PW, all else remains the same, channel list, and those links are identical except the tokens. I handle the EPG myself through SD so that remains the same. Can I just drop in the new M3U link and remove the original one and it will be done....? Please as my 11 year old says "Say yes".... If it's a reseller of the same service, then the answer would be "yes"
EODCrafter 181 Posted August 14, 2019 Author Posted August 14, 2019 same username, different PW, all else remains the same, OP Made this Pretty clear......
kanipek 230 Posted August 14, 2019 Posted August 14, 2019 Well I took the plunge. Set up a COPY of my production server, add xTeVe as an M3U Tuner and as a guide source - and well not much success. Looks like it read the M3U tuner but the guide data was a no show, even though reading the log it looked to be fine. So I deleted ALL tuners and ALL guide sources and did a restart of Emby. Added the xTeVe info back in and now it looks good...?? Is this common? Does xTeVe not play nice with existing HDHR/IPTV installations? I was very careful with channel numbering(xTeVe) so there wouldn't be duplicate channels. But there are more than a few channel names that are identical. Ideas?
EODCrafter 181 Posted August 15, 2019 Author Posted August 15, 2019 (edited) Well I took the plunge. Set up a COPY of my production server, add xTeVe as an M3U Tuner and as a guide source - and well not much success. Looks like it read the M3U tuner but the guide data was a no show, even though reading the log it looked to be fine. So I deleted ALL tuners and ALL guide sources and did a restart of Emby. Added the xTeVe info back in and now it looks good...?? Is this common? Does xTeVe not play nice with existing HDHR/IPTV installations? I was very careful with channel numbering(xTeVe) so there wouldn't be duplicate channels. But there are more than a few channel names that are identical. Ideas? "All else remains the same" didn't really mean that I take? It should of been....Delete old m3u/playlist link and xmltv link, insert new ones, and be done. Just the Password changing would not do what you are describing. @@marmei Don't forget, if your Password for the M3U changed, then the one for the XMLTV (Guide) file changed as well. Does xTeVe not play nice with existing HDHR/IPTV installations? What do you Mean by this? An actual Hardware HDHR Tuner? xTeVe is made for IPTV, but it also supports HDHR Tuner Cards, These must be added after IPTV AFAIK, I don't have one. Edited August 15, 2019 by EODCrafter
kanipek 230 Posted August 15, 2019 Posted August 15, 2019 What do you Mean by this? An actual Hardware HDHR Tuner?--->>Yes an actual HDHR tuner. I have several existing for OTA. xTeVe is made for IPTV, but it also supports HDHR Tuner Cards, These must be added after IPTV AFAIK, I don't have one.--->>>And this I believe answers the question I had -- I initially added the xTeVe M3U/XML to my (copy of) my existing install, which includes my OTA HDHR tuners and my original IPTV setup. The channels appeared from xTeVe but no guide data. So I deleted ALL tuner/guide data and restarted Emby then xTeVe was added without issue.
stevedawg85 2 Posted October 29, 2019 Posted October 29, 2019 Any1 care to share suggestions/opinions on channel configuration w/ multiple iptv services? I've signed up for 2, trying to figure out if i want them completely separated, or lumped together like ESPN's etc. Anyone rename the channel like Service 1 ESPN and Service 2 ESPN? 1
EODCrafter 181 Posted October 30, 2019 Author Posted October 30, 2019 (edited) Any1 care to share suggestions/opinions on channel configuration w/ multiple iptv services? I've signed up for 2, trying to figure out if i want them completely separated, or lumped together like ESPN's etc. Anyone rename the channel like Service 1 ESPN and Service 2 ESPN? What I do in xTeVe is Renumber the Channels 4, 4.1, 4.2 ECT to match all my NBC Channels (same as any Dupes like ESPN). Renaming Channels seems rather cumbersome. You can also upload Custom Logos in xTeVe if you desire They show up in Emby like this....... Edited October 30, 2019 by EODCrafter 1
Spaceboy 2573 Posted October 30, 2019 Posted October 30, 2019 What I do in xTeVe is Renumber the Channels 4, 4.1, 4.2 ECT to match all my NBC Channels (same as any Dupes like ESPN). Renaming Channels seems rather cumbersome. You can also upload Custom Logos in xTeVe if you desire They show up in Emby like this....... Does xteve have the grouping of channels across iptv providers as a goal? Sent from my SM-T510 using Tapatalk
stevedawg85 2 Posted October 30, 2019 Posted October 30, 2019 Awesome thanks, didn't think of that, great idea! Think I'll follow a similar rule! What I do in xTeVe is Renumber the Channels 4, 4.1, 4.2 ECT to match all my NBC Channels (same as any Dupes like ESPN). Renaming Channels seems rather cumbersome. You can also upload Custom Logos in xTeVe if you desire They show up in Emby like this.......
EODCrafter 181 Posted October 30, 2019 Author Posted October 30, 2019 (edited) Does xteve have the grouping of channels across iptv providers as a goal? Sent from my SM-T510 using Tapatalk Unfortunately not, we are Still waiting on @@Luke to implement this feature Edited October 30, 2019 by EODCrafter 1
dcol 177 Posted October 30, 2019 Posted October 30, 2019 (edited) Also waiting on using multiple IPTV providers to schedule same show at same time for redundancy purposes. Not having this option bit me last night when one of my IPTV providers went south and I missed a recording. We really need this option due to the instability of IPTV. Edited October 30, 2019 by dcol 1
