alexpaton 10 Posted June 12, 2019 Posted June 12, 2019 flipper26Do you leave xteve running? If it isn't running, when Emby refreshes its guide, it will update with nothing - result, no guide.
dcol 177 Posted June 12, 2019 Posted June 12, 2019 flipper26 Do you leave xteve running? If it isn't running, when Emby refreshes its guide, it will update with nothing - result, no guide. That is not true. It will update with the last m3u produced. xTeVe does not remove the m3u when it isn't running. 1
alexpaton 10 Posted June 12, 2019 Posted June 12, 2019 I was talking about the guide, not the m3u. the channels remain, but the EPG is empty. It happened to me the other day.
dcol 177 Posted June 12, 2019 Posted June 12, 2019 I was talking about the guide, not the m3u. the channels remain, but the EPG is empty. It happened to me the other day. The only way the guide would be empty is if the m3u was older than the # of scheduled days.
alexpaton 10 Posted June 12, 2019 Posted June 12, 2019 Why would the age of the m3u be of relevance to the guide? There is no guide data in it, apart from channel name & number.
alexpaton 10 Posted June 12, 2019 Posted June 12, 2019 Actually, forget that. We are BOTH wrong. if xteve is not running when emby updates the guide, the channels get wiped out as well.
Luke 42242 Posted June 12, 2019 Posted June 12, 2019 if xteve is not running when emby updates the guide, the channels get wiped out as well. This is something we'll be looking at improving. Thanks. 1
flipper26 0 Posted June 12, 2019 Posted June 12, 2019 Actually, forget that. We are BOTH wrong. if xteve is not running when emby updates the guide, the channels get wiped out as well. That hasn't been the case for me. I usually update emby without xteve running and the channels are all there and the EPG has been okay after i update. I have xteve running on my laptop and emby server is on a Shield.
alexpaton 10 Posted June 12, 2019 Posted June 12, 2019 if you are running xteve like that, it is worth adding the m3u and xml as paths to file, rather than http links. That way, neither emby or xteve care whether the other is running. 1
flipper26 0 Posted June 12, 2019 Posted June 12, 2019 if you are running xteve like that, it is worth adding the m3u and xml as paths to file, rather than http links. That way, neither emby or xteve care whether the other is running. That's correct. I'm not using the http links but rather links to the files on my laptop. I'd prefer to having xteve run directly on the Shield but I didn't know how to set that up. If you can point me to any documentation on how to do it I'd appreciate it. Thanks.
alexpaton 10 Posted June 12, 2019 Posted June 12, 2019 I'm afraid i'm not a Shield user. I know there are 2 or 3 that run it on shield. The documentation for several different installs are on the discord channel in #read-first
flipper26 0 Posted June 12, 2019 Posted June 12, 2019 I had this Emby Guide showing up perfectly yesterday in a grid with the timeline across the top and the channels listed on the lefthand side and program information. Today, no matter what I do I can't get the Guide to display in a grid formation. I can get the grid on my laptop when I login to the Emby server and also on my Shield (which is where I have the Emby server). However, I can't get the grid on my Apple TV where I want to watch content using Emby. Does anyone have any ideas? thanks.
EODCrafter 181 Posted June 13, 2019 Author Posted June 13, 2019 (edited) That's correct. I'm not using the http links but rather links to the files on my laptop. I'd prefer to having xteve run directly on the Shield but I didn't know how to set that up. If you can point me to any documentation on how to do it I'd appreciate it. Thanks. Use Termux to install xTeVe ARM64 Version on the Shield. Sry, but the scope of using Termux and Linux commands/permissions are Individual to your Environment. Edited June 15, 2019 by EODCrafter 1
Senna 368 Posted June 13, 2019 Posted June 13, 2019 I can't get the grid on my Apple TV where I want to watch content using Emby. There is NO "Grid Style" Live TV program guide for the Emby Apple TV app available yet... See item 2 here
st8ofgrace 1 Posted June 14, 2019 Posted June 14, 2019 (edited) look who's calling the kettle black on that one....daaannnggg I think you wasted more hot air complaining than actually offering your "expertise" to noobs like myself. much thanks to everyone who offered real help and to those who spoke up dispite a-holes and naysayers. Edited June 14, 2019 by st8ofgrace 1
flipper26 0 Posted June 16, 2019 Posted June 16, 2019 In xteve I have renumbered the channels and grouped similar items together. For a number of the channels Emby continues to display them incorrectly no matter what I do. For instance, in xteve, I have numbered 131 to be CA: Discovery Science HD and that's how it reads in the xml file that xteve creates. Emby shows the channel and logo as belonging to Bravo. The programming that is displayed is correct as Discovery Science. In Emby I am only pulling the m3u and the xml from the latest xteve files, no other Guide data. When I look at the Emby mapping it shows as: 131 CA: DISCOVERY SCIENCE HDCA: DISCOVERY SCIENCE HD - XmlTV I've tried logging out and logging back in again. Why does Emby do this and how do I fix it? thanks.
Sammy 791 Posted June 16, 2019 Posted June 16, 2019 (edited) In xteve I have renumbered the channels and grouped similar items together. For a number of the channels Emby continues to display them incorrectly no matter what I do. For instance, in xteve, I have numbered 131 to be CA: Discovery Science HD and that's how it reads in the xml file that xteve creates. Emby shows the channel and logo as belonging to Bravo. The programming that is displayed is correct as Discovery Science. In Emby I am only pulling the m3u and the xml from the latest xteve files, no other Guide data. When I look at the Emby mapping it shows as: 131 CA: DISCOVERY SCIENCE HD CA: DISCOVERY SCIENCE HD - XmlTV I've tried logging out and logging back in again. Why does Emby do this and how do I fix it? thanks. Take a look at post 38 here.@@Luke any way to fix this? https://emby.media/community/index.php?/topic/74239-Live-TV-Setup&do=findComment&comment=752340 Sent from my SM-G960U1 using Tapatalk Edited June 16, 2019 by Sammy 1
EODCrafter 181 Posted June 16, 2019 Author Posted June 16, 2019 In xteve I have renumbered the channels and grouped similar items together. For a number of the channels Emby continues to display them incorrectly no matter what I do. For instance, in xteve, I have numbered 131 to be CA: Discovery Science HD and that's how it reads in the xml file that xteve creates. Emby shows the channel and logo as belonging to Bravo. The programming that is displayed is correct as Discovery Science. In Emby I am only pulling the m3u and the xml from the latest xteve files, no other Guide data. When I look at the Emby mapping it shows as: 131 CA: DISCOVERY SCIENCE HDCA: DISCOVERY SCIENCE HD - XmlTV I've tried logging out and logging back in again. Why does Emby do this and how do I fix it? thanks. I delete the entire cache file and let it rebuild from scratch....Hang on, I'll get directory..... 1
Sammy 791 Posted June 16, 2019 Posted June 16, 2019 I delete the entire cache file and let it rebuild from scratch....Hang on, I'll get directory..... You delete that directory then do a library scan? Some of xTeVe logos are dark and don't show well so need replacement anyhow. Sent from my SM-G960U1 using Tapatalk
EODCrafter 181 Posted June 16, 2019 Author Posted June 16, 2019 (edited) You delete that directory then do a library scan? Some of xTeVe logos are dark and don't show well so need replacement anyhow. Sent from my SM-G960U1 using Tapatalk Actually a Channel scan is what reloads it. >>> Live TV >>> Refresh Guide Data Edited June 16, 2019 by EODCrafter 1
EODCrafter 181 Posted June 16, 2019 Author Posted June 16, 2019 You delete that directory then do a library scan? Some of xTeVe logos are dark and don't show well so need replacement anyhow. Sent from my SM-G960U1 using Tapatalk @@marmei just unveiled in xTeVe Beta the ability to simply upload logos in Mapping. Pretty Sweet! Ask for a Beta Trial @@Sammy 1
Spaceboy 2573 Posted June 17, 2019 Posted June 17, 2019 In xteve I have renumbered the channels and grouped similar items together. For a number of the channels Emby continues to display them incorrectly no matter what I do. For instance, in xteve, I have numbered 131 to be CA: Discovery Science HD and that's how it reads in the xml file that xteve creates. Emby shows the channel and logo as belonging to Bravo. The programming that is displayed is correct as Discovery Science. In Emby I am only pulling the m3u and the xml from the latest xteve files, no other Guide data. When I look at the Emby mapping it shows as: 131 CA: DISCOVERY SCIENCE HD CA: DISCOVERY SCIENCE HD - XmlTV I've tried logging out and logging back in again. Why does Emby do this and how do I fix it? thanks. emby uses 3 digit channel numbers to match to gracenote guide data. You must use 4 digit numbers eg 1001
EODCrafter 181 Posted June 17, 2019 Author Posted June 17, 2019 (edited) emby uses 3 digit channel numbers to match to gracenote guide data. You must use 4 digit numbers eg 1001 Your saying you have to use 4 digit numbers in xTeVe? This is not so. My Channels start at 1-700. If you meant Emby, Sry Let me clarify: By default xTeVe starts numbering at 1000 to give you the space between 1-999 to renumber the Channels. Edited June 17, 2019 by EODCrafter
