Info1 13 Posted April 13, 2014 Posted April 13, 2014 (edited) Hi, I have Vmedia's vbox, an android box, I installed XBMC from the application list then in XBMC I added XBMB3C. When I run it I get the same error as this user: http://mediabrowser.tv/community/index.php?/topic/5307-how-to-set-up-xbmb3c/?hl=setup&do=findComment&comment=78008 I could not reply to that thread it as it was closed. My server is running fine, I have 4 Ipads that connect, my Xbox runs off it. I just don't understand how to enter configuration for XBMB3C. I just get an error unable to connect to server. which makes sense as I can't enter setup to tell it where the server is. Can someone please guide me how to open setup on XBMB3C? Sorry for the handout ask. m Edited April 13, 2014 by Info1
Solution xnappo 1611 Posted April 13, 2014 Solution Posted April 13, 2014 You need to go into the context menu to set it up. 'c' on the keyboard, or right-click with the mouse. xnappo 1
