Kimballslice1890 8 Posted October 22, 2018 Posted October 22, 2018 Was wondering if there was a way to enable the channel numbers in the Live TV Channel guide on android? I have a lot of channels, searching them hangs up the server and scrolling through them I can easily get lost as to where I am in the lineup.
Luke 42244 Posted October 22, 2018 Posted October 22, 2018 It will show channel numbers on larger screens. We don't currently show them on phone layouts. We'd have to rethink the design a little bit in order to do that. Thanks.
Kimballslice1890 8 Posted October 31, 2018 Author Posted October 31, 2018 Thanks for the prompt response. I have noticed the numbering on my fire sticks and web interface devices. Android tablet suffers from lack of channel numbering also. Usually only need this feature when i am trying to setup a recording. Navigating to the channel itself via the channel tab could work if when selecting the channel the guide and listing information is incorporated in that? I am not a developer so I am not sure how much time and thought it would take to reconsider designs like this, just some feedback from an end user pov.
samuelqwe 317 Posted November 1, 2018 Posted November 1, 2018 Thanks for the prompt response. I have noticed the numbering on my fire sticks and web interface devices. Android tablet suffers from lack of channel numbering also. Usually only need this feature when i am trying to setup a recording. Navigating to the channel itself via the channel tab could work if when selecting the channel the guide and listing information is incorporated in that? I am not a developer so I am not sure how much time and thought it would take to reconsider designs like this, just some feedback from an end user pov. You can also use to search feature to search for a channel or a specific program.
Luke 42244 Posted November 1, 2018 Posted November 1, 2018 It's really just a question of what the layout would look like and what the trade-offs would be.
Kimballslice1890 8 Posted November 1, 2018 Author Posted November 1, 2018 You can also use to search feature to search for a channel or a specific program. I have tried the search feature, but with the current load times of the Guide, searching can hang up the server. Regardless if I terminate the search when I realize its beginning to freeze, it will stay frozen for a set amount of time until the search is complete.
Luke 42244 Posted November 1, 2018 Posted November 1, 2018 Search performance will be improved with the next release of the server, thanks.
