wangfei 1 Posted October 22, 2018 Posted October 22, 2018 Before the film directory video added to the collection, in addition to the new collection directory will be generated, the original film directory under the film will become a collection, now become only the collection directory is a collection, let the movie directory is just a film, I ask you if I set the problem, or the server version of the update As a result, is that what it is now?
Luke 42213 Posted October 22, 2018 Posted October 22, 2018 Hi, sorry I don't quite understand. Can you go over an example? @@Happy2Play do you have any idea what the question is here?
Happy2Play 9805 Posted October 22, 2018 Posted October 22, 2018 Are you talking about the "Group items into collections" setting? dashboard-library-display
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 Are you talking about the "Group items into collections" setting? dashboard-library-display yes,That's what it means.Is it a question of setting up?
Luke 42213 Posted October 22, 2018 Posted October 22, 2018 Have you created collections for your movies?
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 Have you created collections for your movies? YES
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 Have you created collections for your movies? 图一 图二 Figure 1 shows the poster wall interface of my Android set-top box.The Harry Potter show is a collection of the entire series, but Emby's catalogue shows just eight separate separate films. The collection is displayed in a separate directory.But before emby was shown like Figure 1, now I set the problem or the software update changed the presentation.
Happy2Play 9805 Posted October 22, 2018 Posted October 22, 2018 Did you enable the "Group items into collections" setting? What server version are you on?
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 Did you enable the "Group items into collections" setting? What server version are you on? 3.5.3.0.Where is that set? I didn't set it up before, as shown in Figure 1.
Happy2Play 9805 Posted October 22, 2018 Posted October 22, 2018 3.5.3.0.Where is that set? I didn't set it up before, as shown in Figure 1. It was shown in post 3. Dashboard-Library-Display
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 It was shown in post 3. Dashboard-Library-Display The last step . “Display”I didn't find it anywhere.
Happy2Play 9805 Posted October 22, 2018 Posted October 22, 2018 (edited) Look at the header tabs at the top of the Library page. Note if you are login in via app.emby.media this setting is currently not visible, as the online web app is ahead of the stable server. Edited October 22, 2018 by Happy2Play
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 Look at the header tabs at the top of the Library page. Note if you are login in via app.emby.media this setting is currently not visible, as the online web app is ahead of the stable server. Thank you very much indeed. I am not familiar with this software, thanks to the help of the forum, I often recommend this software in the PT enthusiasts forum in China, after the introduction of transparent themes than plex is much better.
wangfei 1 Posted October 22, 2018 Author Posted October 22, 2018 Look at the header tabs at the top of the Library page. Note if you are login in via app.emby.media this setting is currently not visible, as the online web app is ahead of the stable server. By the way, why do you have so many movies on your cover, and I can only show four, settings or plug-ins?
Happy2Play 9805 Posted October 22, 2018 Posted October 22, 2018 By the way, why do you have so many movies on your cover, and I can only show four, settings or plug-ins? Those are custom images I captured back when dynamic images where add to the server. They have evolved to what you see today.
