solabc16 379 Posted October 24, 2018 Posted October 24, 2018 Hi @@Volkmar Can you attach your most recent server log, that includes the tests you've run above, as there's not much to go on in the previous log. Best - James
Volkmar 14 Posted October 24, 2018 Author Posted October 24, 2018 (edited) Here you go. This is the current server log. I'm just thinking about do deinstall emby from this DS and reinstall. Log.txt Edited October 24, 2018 by Volkmar
solabc16 379 Posted October 24, 2018 Posted October 24, 2018 Thanks for the log, I'll have a look now, I would not expect an uninstall/reinstall to make any difference. Best - James
Volkmar 14 Posted October 24, 2018 Author Posted October 24, 2018 I guess I've found something: it seems it's anything with TheMovieDB because even I've entered the IMDB Id, the result page was black, I've tried this at 4 different movies. By trying the 5th movie I've got a result, so maybe it's an external issue. However, to apply the changes an update the movie takes nearly ages (up to 5 minutes) and there is still the issue with library picture.
solabc16 379 Posted October 24, 2018 Posted October 24, 2018 Hi @@Volkmar I can see the requests in the log now, for example:- https://api.themoviedb.org/3/search/movie?api_key=f6bd687ffa63cd282b6ff2c6877f2669&query=Prophezeihung&language=de https://private.omdbapi.com?apikey=fe53f97e&plot=full&r=json&s=Prophezeihung&type=movie https://image.tmdb.org/t/p/original/XcxWkShvuanQwLDE2Iz4JCq1QX.jpg ...which you can load in a browser and see the result. There are some errors relating to OpenSubtitles, due to the request rate... Error getting response from https://api.opensubtitles.org/xml-rpc System.Net.WebException: The remote server returned an error: (429) Too Many Requests. ...but nothing to worry about in particular, they're usually transient. You can scan through the log for similar entries and confirm if the metadata is actually available. How have you got your library configured? Best - James
Luke 42241 Posted October 24, 2018 Posted October 24, 2018 does the browser debug console show any errors?
Volkmar 14 Posted October 24, 2018 Author Posted October 24, 2018 (edited) beside the opensubtitle errors unfortunately not. I just rebuild the library and let scan 10 movies only to test. Do you see any issues in my configuration? after rebuilding the library it seems it's working now. Sorry for causing trouble Edited October 24, 2018 by Volkmar
Luke 42241 Posted October 25, 2018 Posted October 25, 2018 It looks ok to me. Thanks for the feedback.
solabc16 379 Posted October 25, 2018 Posted October 25, 2018 Thanks for the update @@Volkmar, no problem at all. Best - James 1
Volkmar 14 Posted October 26, 2018 Author Posted October 26, 2018 Btw. do you have a solution of my problem mentioned in post #25? There are still no "preview pictures" in the library buttons.
solabc16 379 Posted October 26, 2018 Posted October 26, 2018 Btw. do you have a solution of my problem mentioned in post #25? There are still no "preview pictures" in the library buttons. Hello @@Volkmar I have seen that happen before, but it usually resolves itself after the library has updated; I'm sure its mentioned in another thread on this forum. Sorry I can't give a precise answer or solution, @@Luke any thoughts? Best - James
Luke 42241 Posted October 26, 2018 Posted October 26, 2018 I would suggest re-evaluating those images with the next release. Thanks.
