Mike5123 1 Posted October 19, 2018 Posted October 19, 2018 I'm having problems with the metadata not automatically downloading. I know the problem is the naming convention, but plex was able to correctly identify 99% of my library. Is there any way to get metadata to download properly without renaming or manually identifying my files? If not, how would I use filebot from CLI to mass rename to the proper naming convention?
Happy2Play 9813 Posted October 19, 2018 Posted October 19, 2018 Without more information about your naming convention it is hard to say. Have you checked the metadata providers per library?
Luke 42246 Posted October 19, 2018 Posted October 19, 2018 Hi, yes, let's please go over some specific examples. Thanks !
