cptv 1 Posted October 18, 2018 Posted October 18, 2018 (edited) Great work on this app. Aesthetically I think it's one of my favorites. I'm having an issue with the Live TV program guide however. When scrolling through the guide, channels with no epg data are skipped over. Another issue is that if you come across a channel has no EPG data for the current time but does have EPG data for later in the day- the selection cursor gets completely shifted over to that later time when you continue scrolling. Both problems could be fixed if the guide worked similar to that of the Fire TV app. That app fills in portions of the guide that have no EPG info with a dummy "<No Program Data Available>" entry. Hopefully a fix is quick and easy to implement as I'd love to switch to this as my main TV viewing app. Cheers Edit: I figure I should specify the platform I'm using. I can confirm the behavior on both the Xbox One X app and tv.emby.media portal Edited October 18, 2018 by plexinthecloud
