Might of found a slow down solution, help me test it...
highonascii
Can some of you test something for me that I am testing out for the last three days? In the emby addon settings change playback to only force http and force transcode like in picture above... On my pc things fly open now with pc being on 24/7 and not restarting kodi... I would like to see if this helps people with the "slow down" issue. Thanks
Angelblue05
If it does make a difference then the issue is not the addon itself but how quickly emby / kodi can load emby streams.
highonascii
Exactly what I have been thinking because it doesn't make sense that I wouldn't be affected too. I haven't seen slow down since u fixed it, but keep seeing posts so want to rule out everything
  • Like 1
Still slows down here after watching 3 or 4 shows
Sent from my HTC_M10h using Tapatalk
highonascii
Tested on a different device... still cant reproduce the slow down :/
Guest
