maximilianh75 19 Posted October 24, 2018 Author Posted October 24, 2018 @@maximilianh75 Can you try this build and let me know if the issue still exists? Thanxs Work perfect now. 1
MattBlacK85 0 Posted October 30, 2018 Posted October 30, 2018 I'v tested the addon and it's working with external subs. Great, thank you! But the external subs aren't working on Chromecast and iOS / Android apps. In Google Chrome, Xbox and LG TV app they are working. Is this a bug in the server or are there any issues with the apps?
Luke 42239 Posted October 30, 2018 Posted October 30, 2018 I'v tested the addon and it's working with external subs. Great, thank you! But the external subs aren't working on Chromecast and iOS / Android apps. In Google Chrome, Xbox and LG TV app they are working. Is this a bug in the server or are there any issues with the apps? Please see how to report a media playback issue. thanks.
ntilagoa 12 Posted November 1, 2018 Posted November 1, 2018 Hi Also have this problem on Nvidia shield with latest nightly Kodi 18 and the plugin version 3.1.32b External subtitles or subtitles downloaded from opensubtitles.org do not show up. Log: https://paste.kodi.tv/ligulujoqe
hattori87 0 Posted November 1, 2018 Posted November 1, 2018 (edited) weird... this issue occured with me while using vpn. soon as i disconnected it, i was able to make it work, strange enough. Edited November 1, 2018 by hattori87
Aleta 0 Posted November 1, 2018 Posted November 1, 2018 (edited) Hi Also have this problem on Nvidia shield with latest nightly Kodi 18 and the plugin version 3.1.32b External subtitles or subtitles downloaded from opensubtitles.org do not show up. Log: https://paste.kodi.tv/ligulujoqe Hello Exactly the same problem but client is running on Amazon Fire TV. Not at home at the moment. Later will post log if necessary Edited November 1, 2018 by Aleta
markdj 49 Posted November 3, 2018 Posted November 3, 2018 Had the same problem, but I fixed it by disabling the 'adjust refresh rate' option. Might be worth a try.
Aleta 0 Posted November 3, 2018 Posted November 3, 2018 Hello Something change with latest nightly beta 5. With beta 3 and beta 4 subtitles work ok but not with beta 5
justpig 27 Posted November 6, 2018 Posted November 6, 2018 I am experiencing the same problem with embyCon. Internal subtitles will play but not external ones. I am using latest EmbyCon beta, latest beta Emby server and Kodi Nov 06 nightly build. Tried to enable performance profiling but it just comes up with a popup asking if I want to enable it; click yes and it just pops up again.
Nazgulled 11 Posted November 7, 2018 Posted November 7, 2018 Can you guys confirm if you're having this issue for both Movies and TV Shows? I'm asking this because I'm having a problem (not sure if it's the same one reported here) where external subtitles are not available, but just for TV Shows (Movies have no problems).
justpig 27 Posted November 7, 2018 Posted November 7, 2018 @Nazgulled: It is the same in EmyCon for Movies and TV Shows.
Angelblue05 4132 Posted November 7, 2018 Posted November 7, 2018 hmmm https://forum.kodi.tv/showthread.php?tid=326482
Nazgulled 11 Posted November 7, 2018 Posted November 7, 2018 hmmm https://forum.kodi.tv/showthread.php?tid=326482 Wow, that was definitely my issue. Thank you and sorry for making you think it was a problem with the addon.
Angelblue05 4132 Posted November 7, 2018 Posted November 7, 2018 Hmmm....? https://forum.kodi.tv/showthread.php?tid=337275
justpig 27 Posted November 7, 2018 Posted November 7, 2018 @Angelblue05: I tried changing the position of the subtitles as suggested in the post but that did not resolve the issue. The issue is only with EmbyCon. Emby for Kodi works perfectly with subtitles.
justpig 27 Posted November 7, 2018 Posted November 7, 2018 After playing a number of files it seems that Emby for Kodi recognises the external subtitles properly as regarding their language for example English. However, EmbyCon sees the same external subtitle as unknown as regards to language.
Angelblue05 4132 Posted November 7, 2018 Posted November 7, 2018 (edited) That is because of a limitation in the Kodi api. It takes the language tag from the filename and there's none when using url subtitles (which is part of the emby api). The only reason it works for the emby for kodi addon is because it downloads the subtitles locally with the proper tag and so Kodi recognizes the language. It would be better if the Kodi api simply allowed to name the subtitle track Edited November 7, 2018 by Angelblue05
justpig 27 Posted November 7, 2018 Posted November 7, 2018 Thanks for the explanations null_pointer and Angelblue05.
justpig 27 Posted November 8, 2018 Posted November 8, 2018 @ Thanks for the update, external subtitles are now displaying for the files i have tested so far.
