seangermany 5 Posted October 17, 2018 Posted October 17, 2018 (edited) Hello All, I've recently encountered an issue affecting liveTV. The default audio track on some channels is now SAP. This is normally happening on Live TV events (live sports, Network News). I have to manually change it back to Eng. Other channels now have the descriptive audio/video enabled. This is most annoying, as I cannot find the settings for this anywhere. I have emby installed on nvidia shield, as well as LG OS and Samsung Smart TVs, but the issue is only present on the Samsung tvs. I haven't made any changes to my setup. Can someone please assist? Thanks in advance. embyserver.txt Edited October 17, 2018 by seangermany
krustyreturns 191 Posted October 17, 2018 Posted October 17, 2018 As a workaround, you can set serverwmc to send only one audio stream to emby. See the 'Live TV' tab.
Luke 42237 Posted October 17, 2018 Posted October 17, 2018 Hi, was there an ffmpeg log, and if so, can you attach that too? thanks.
seangermany 5 Posted October 18, 2018 Author Posted October 18, 2018 ffmpeg.log attached. It captures three streams during - Eng, SPA and Video. I've enabled the option to "only remux the default language to output" on server WMC. I'll update on the results. Thanks for your help ffmpeg-remux-f405b79f-3436-457a-bc04-12d9c65c0bda.txt
