Library sync exited. Please report to forum.
Since the TV app is not working out, i thought hey lets try good-old kodi board.
So i installed the Emby addon, signed in w/o error, needed to reboot: "Library sync thread has exited! You should restart Kodi now. Please report this on the forum.".
Well i am reporting this on the forum as asked.
Emby server 3.5.3.0
Kodi companion 2.0.3.0
Kodi 18 Leia
Kodi Emby-addon 3.0.34
https://pastebin.com/raw/QtKs3d1L
FYI, i removed my IP and DeviceID.
*Edit: Added server+player versions.
Edited by k0Lm.
Angelblue05
The stable version of the addon does not support Leia beta 3. You have to use the beta version of the addon for this to work. You can install the beta repo from kodi.emby.media
At first it worked, and now nothing. it doesnt even boot anymore.. :P Kernel panic's. Ah well.
Edited by k0Lm.
Angelblue05
At first it worked, and now nothing. it doesnt even boot anymore.. [emoji14] Kernel panic's. Ah well.
Sorry?? Can you provide your log? What doesn't boot? Kodi? Edited by Angelblue05
It's crashing in the middle of scans and saying kernel panic on the screen. But never mind, im done with it. Thanks anyway
Angelblue05
Ok, do you have force artwork caching enabled (addon settings > sync)? If so disable it. Kodi does seem to have some difficulty with it on lower powered devices. I'm still making changes, this is beta. Thanks for your help testing.
Guest
