JotNarayan 4 Posted October 16, 2018 Posted October 16, 2018 Emby server running on DS218play. - I have created a library to be able to store pdf documents, but I can only see them. Your content can not be opened. - Trailers only work in movies. In the series no. - Although Emby has been configured so that it does not show the subtitles, they continue to appear randomly (from LG Smart TV, since PC works well) Even movies with subtitles for the hearing impaired appear and it is impossible to remove them. - The navigation through the menus from Smart TV LG is very slow, since PC is acceptable. - I have created a library to store my photos, and when I try to view them from LG Smart TV the process becomes so slow that you end up leaving it. It is totally unfeasible. Visualized from PC works fine. If I detect more things I will expand them. My tv is the LG UF6807 model
Luke 42241 Posted October 16, 2018 Posted October 16, 2018 Thanks for the feedback. We will look into these.
