swapnilsawant 0 Posted April 12, 2014 Posted April 12, 2014 I get an option to group versions. But how do I ungroup the group version if required. Unable to find any ungroup version option.
Kylar 3 Posted September 13, 2014 Posted September 13, 2014 Hey there, I know this was from a while back but I recently came across this same issue and eventually found the solution. Select your grouped file (most likely from the "movies" section I assume) and scroll down to "Media Info." Click the + and you should now have an option called "Split Versions Apart." Click it and then the "OK" and they will revert back to their original state. 2 1
quackpipe 11 Posted December 24, 2019 Posted December 24, 2019 Thanks for this, Solved my problem. Hey there, I know this was from a while back but I recently came across this same issue and eventually found the solution. Select your grouped file (most likely from the "movies" section I assume) and scroll down to "Media Info." Click the + and you should now have an option called "Split Versions Apart." Click it and then the "OK" and they will revert back to their original state.
Cluttered 15 Posted October 12, 2023 Posted October 12, 2023 Is there any way to disable the group versions? I am importing my iTunes library and this is a pain in the neck, I have to check how many files there should be, then see what the count in emby is and when the two differ I have to go through each one to find which need 'splitting'. I'd much rather it left things alone and allowed me to manually group them if ever I found it necessary.
Luke 42185 Posted October 12, 2023 Posted October 12, 2023 43 minutes ago, Cluttered said: Is there any way to disable the group versions? I am importing my iTunes library and this is a pain in the neck, I have to check how many files there should be, then see what the count in emby is and when the two differ I have to go through each one to find which need 'splitting'. I'd much rather it left things alone and allowed me to manually group them if ever I found it necessary. Hi, what was grouped that you're rather not?
