h3hl33t 1 Posted October 13, 2018 Posted October 13, 2018 So I am experiencing a weird issue with my Guide. It only shows data for the majority of my channels for 5 or so hours out. Some other channels are extended out further. I have set the setting in DVR to allows for 7 days of guide. Any ideas what I am missing?
h3hl33t 1 Posted October 13, 2018 Author Posted October 13, 2018 Nevermind, that is how far out it is on other apps that use the EPG.
Luke 42213 Posted October 13, 2018 Posted October 13, 2018 Hi, what is the source of the guide data? 1
Luke 42213 Posted October 13, 2018 Posted October 13, 2018 So you're using xmltv? Did you check to see how many days of guide data it has in the XML?
pir8radio 1313 Posted October 13, 2018 Posted October 13, 2018 (edited) I'm seeing the same issue.. I'm also seeing emby caching (and never deleting) the xmltv files, each one is 77MB and they have eaten up 10 gigs on my emby server in the cache folder... Edited October 14, 2018 by pir8radio
h3hl33t 1 Posted October 13, 2018 Author Posted October 13, 2018 I logged a point with VS/MS support about the guide issue.
pir8radio 1313 Posted October 14, 2018 Posted October 14, 2018 This might be a provider issue. However there does seem to be a cache issue where xmltv files just keep eating up disk space day after day.
h3hl33t 1 Posted October 14, 2018 Author Posted October 14, 2018 I am seeing the same in the xmltv directory. Maybe there is a purge job that needs to be setup? Sent from my moto x4 using Tapatalk
Luke 42213 Posted October 14, 2018 Posted October 14, 2018 Did you check to see how many days of guide data it has in the XML?
pir8radio 1313 Posted October 14, 2018 Posted October 14, 2018 Did you check to see how many days of guide data it has in the XML? Looks like 5 days
