borygo77 2 Posted July 12, 2019 Posted July 12, 2019 Had this installed Luke but came back to 3.5.3. Hate the way 4.1 is sorting TV Shows... Can't say if 4.1 had same error.... never checked
borygo77 2 Posted July 12, 2019 Posted July 12, 2019 This is my log right after restart..... Will you have a look what's wrong with it please ? embyserver.txt
Happy2Play 9814 Posted July 12, 2019 Posted July 12, 2019 This is my log right after restart..... Will you have a look what's wrong with it please ? Might not be related but you have a plugin issue since you have changed Emby versions as they are not compatible with previous version (upgrading/downgrading). Unfortunately can't tell which plugins these are, so you will need to uninstall and reinstall plugins. Error App: LoaderException: Could not load file or assembly
borygo77 2 Posted July 12, 2019 Posted July 12, 2019 Seen it in log and was wondering if you'll be able to solve it somehow
Happy2Play 9814 Posted July 12, 2019 Posted July 12, 2019 Seen it in log and was wondering if you'll be able to solve it somehow In 4.2+ it will handle server installed plugins better but all additional users added plugins will require manual intervention. I use the Server Configuration Backup plugin so the plugin folder is backed up so I am able restore from backup if ever needing to do a downgrade version like this. I run the task to make a manual backup and rename the folder to that version and restore specific sections that were backed up.
borygo77 2 Posted July 12, 2019 Posted July 12, 2019 Does 4.2+ has fixed TV Shows sorting problem I had with 4.1 ?
Happy2Play 9814 Posted July 12, 2019 Posted July 12, 2019 Does 4.2+ has fixed TV Shows sorting problem I had with 4.1 ? Sorry is this issue discussed somewhere?
borygo77 2 Posted July 12, 2019 Posted July 12, 2019 Well can't find it now as it was 2 months I've tried 4.1... There is some change in emby server 4 to folder structure causing mess in my library It's perfect in 3.5.3...
Happy2Play 9814 Posted July 12, 2019 Posted July 12, 2019 Well can't find it now as it was 2 months I've tried 4.1... There is some change in emby server 4 to folder structure causing mess in my library It's perfect in 3.5.3... There were a lot of changes to folder detection in TV and Mixed content. But you would have to go over your issues with some specific examples. But I would do it in a new topic if you can't find a topic that applies.
Luke 42246 Posted July 13, 2019 Posted July 13, 2019 There are some fixes in 4.2 for non standard folder structures, but there shouldn't be any issues in 4.1 with everything listed in the TV naming wiki.
ddurdle 75 Posted July 22, 2019 Author Posted July 22, 2019 The websocket issue doesn't exist on 4.1 and 4.2 so I'd recommend upgrading.
