backmail 0 Posted October 10, 2018 Posted October 10, 2018 i recently had an emby install, and tried scanning my media. Emby was unable to identify metadata for the below movies, but Plex was easily able to identify everything. I havent specifically renamed it in particular way. Examples of the path: /data/movies/The Edge of Seventeen 2016 1080p BluRay x264 DTS-JYK/The Edge of Seventeen 2016 1080p BluRay x264 DTS-JYK.mkv /data/movies/War Dogs 2016 1080p BluRay x264 DTS-JYK/War Dogs 2016 1080p BluRay x264 DTS-JYK.mkv /data/movies/Snowden 2016 1080p BluRay x264 DTS-JYK/Snowden 2016 1080p BluRay x264 DTS-JYK.mkv /data/movies/Lion King the Trilogy 1-3 1994-2004 BluRay 720p x264 aac jbr/Lion King 2 1998 Simba's Pride.mp4 Any advice how i can make emby identify these movies, without significantly renaming the stuff around, would be greatly appreciated Note: I have used plex sporadically over the last 5 years, and i rarely had a scenario where it wasn't able too fetch metadata for a movie i had watched. Thanks.
ebr 16310 Posted October 10, 2018 Posted October 10, 2018 Hi. You will either need to make your folder names more closely match our guidelines (Movie naming) or use our manual identify feature to correct the mis-identified ones. We support a lot more features like multi-versioning than they do so we require a bit more precise naming in some instances. Thanks.
backmail 0 Posted October 10, 2018 Author Posted October 10, 2018 Thanks for the quick reply. I was afraid you would say that! Just a suggestion: Lot of ordinary users might not care about advanced features like muti-versioning, but they might see that nearly 30% of the movies are not identified by emby , but by Plex, and might be put of by that unidentified tiles in the library. I have been reading about Plex Vs Emby articles over the last few days, and everybody's number 1 comment is always the metadata issue. Just wondering whether you guys are aware of it. And the No-1 compliment about emby is the quick support you recieve here, and thanks for that. Keep doing great work !
StewieGreen 160 Posted October 10, 2018 Posted October 10, 2018 Checkout FileBot. If you're willing to do some learning and playing around, it'll do all the work automatically for you - renaming and file organization - without touching a thing
Luke 42213 Posted October 10, 2018 Posted October 10, 2018 These examples really ought to just work i would think.
Carlo 4561 Posted October 10, 2018 Posted October 10, 2018 I have been reading about Plex Vs Emby articles over the last few days, and everybody's number 1 comment is always the metadata issue. Just wondering whether you guys are aware of it. Only by those that don't follow directions or guides for EITHER program. Both Plex and Emby essentially use the same naming conventions and are pretty tolerable to variations but you have to make an effort to get close to it. This is one of the "easiest problems" to solve as there are many utils such as filebot that will do the work for you. You can run them via GUI or script them so they do the proper naming and even put the media in the correct place on your server for you.
Luke 42213 Posted October 10, 2018 Posted October 10, 2018 Our scanning has also improved a lot recently and a lot of the comments I typically see are from people who tried us a while ago and haven't tried again lately. 1
