zeldridge 0 Posted October 10, 2018 Posted October 10, 2018 Hi, First question: When I try to watch a 4K movie, the quality auto selects to "1080p - 50 Mbps" when I hit play. I get a note in the stats box: "Reason for transcoding: media bitrate exceeds limit". How do I raise the bitrate limit on the LG app so the quality isn't changed automatically? Second question: My TV doesnt support TrueHD Audio, is there a way for the Emby on WebOS to choose the next best audio track for the movie and exclude TrueHD so my movie is played directly? Thanks
Luke 42234 Posted October 10, 2018 Posted October 10, 2018 Hi, are you on the same local network as the server, or no? For #2, yes that is something we'll be looking at in a future update. Thanks.
zeldridge 0 Posted October 11, 2018 Author Posted October 11, 2018 Hi Luke, Yes the server is connect to the same network using Unraid. When I select 4K - 120 Mbps in the quality option it runs fine however.
Luke 42234 Posted October 11, 2018 Posted October 11, 2018 Ok so just select 4K 120 and then the app will remember that. Please let us know if this helps. Thanks.
