Guest asrequested Posted October 10, 2018 Posted October 10, 2018 It appears to be avoiding the year, and creating a new directory
Guest asrequested Posted October 11, 2018 Posted October 11, 2018 By the lack of response, this is either of no consequence or the server has no control over it?
Carlo 4561 Posted October 11, 2018 Posted October 11, 2018 It does this in a few places including Active Records, Schedule and Series. No way to currently update the info to make it match. I've got a dozen or so shows like this.
Guest asrequested Posted October 11, 2018 Posted October 11, 2018 I'm aware that it's probably because there was no (year) in the guide data, but since the change to use the year when recording is recent, I thought I'd report it. It's annoying. We were forced to merge our recording folders because of the year. Now it appears we need to continually do that.
kanipek 230 Posted October 11, 2018 Posted October 11, 2018 I'm aware that it's probably because there was no (year) in the guide data, but since the change to use the year when recording is recent, I thought I'd report it. It's annoying. We were forced to merge our recording folders because of the year. Now it appears we need to continually do that. There is a date(at least using XMLTV). It is not the year it premiered though but the date of the airing. I don't know if it is possible to use that in some way (talking Emby-Server) or not. <programme start="20181017000000" stop="20181017010000" channel="EPG123.34516.schedulesdirect.org"> <title>The Flash</title> <sub-title>Blocked</sub-title> <desc>Barry and Team Flash track down a meta that is stealing high-tech weapons, only to cross paths with a new foe named Cicada, who is hunting the very same meta, with nefarious intent. Season 05, Episode 02</desc> <credits> <director>Kim Miles</director> <actor role="Barry Allen/The Flash">Grant Gustin</actor> <actor role="Iris West">Candice Patton</actor> <actor role="Caitlin Snow">Danielle Panabaker</actor> <actor role="Cisco Ramon/Vibe">Carlos Valdes</actor> <actor role="Dr. Harrison Wells">Tom Cavanagh</actor> <actor role="Detective Joe West">Jesse L. Martin</actor> <actor role="Julian Albert">Tom Felton</actor> <writer>Eric Wallace</writer> <writer>Judalina Neira</writer> <producer>Greg Berlanti</producer> <producer>Andrew Kreisberg</producer> <producer>David Nutter</producer> <producer>Sarah Schechter</producer> <guest>Jessica Parker Kennedy</guest> <guest>Chris Klein</guest> </credits> <date>20181016</date> <category>Series</category> <category>Drama</category> <category>Action</category> <category>Adventure</category> <category>Fantasy</category> <language>en</language> <icon src="https://s3.amazonaws.com/schedulesdirect/assets/p10781465_b_h3_af.jpg" /> <episode-num system="dd_progid">EP01922936.0099</episode-num> <episode-num system="xmltv_ns">4.1.0/1</episode-num> <video> <quality>HDTV</quality> </video> <audio> <stereo>dolby digital</stereo> </audio> <new /> <subtitles type="teletext" /> <rating system="VCHIP"> <value>TV-PG</value> </rating> <rating system="USA Parental Rating"> <value>TVPG</value> </rating> </programme>
Guest asrequested Posted October 11, 2018 Posted October 11, 2018 It was recording the season premiere while I posted. So it actually had the correct date. So this shouldn't have happened.
Diedrich 380 Posted October 11, 2018 Posted October 11, 2018 (edited) I've been living with this for over a year, it's a bit distracting. As mentioned above, there is currently no way to edit the schedule info, and there is no way to edit the channel numbers. Both are minor annoyances that will hopefully garner some attention. For me, it's The Flash and America's Test Kitchen that have naming/identification issues. Edited October 11, 2018 by Diedrich
Carlo 4561 Posted October 11, 2018 Posted October 11, 2018 I post process the files and move them from Recordings to Movies and TV Shows with a rename via FileBot. I try and keep my actual Recording directory empty (everything processed as quickly as possible). That helps for the recordings themselves (everyone else) but doesn't help me with the schedules and series tab.
Luke 42217 Posted October 12, 2018 Posted October 12, 2018 We'll have no choice then but to just save the poster from the guide data as your series poster.
Carlo 4561 Posted October 12, 2018 Posted October 12, 2018 That isn't the issue. It's when Emby tries to match the show on it's own. Try recording "The Five" 5pm Fox News for a perfect example. You will probably not have Guide EPG picture info for that. However if you set it up as a series it will match the tv show "The Five" even if you don't have that on your system but do have many other episode of the news show. That also affect the "don't record episodes that already exist" as well. Same issue with many of the reboot shows or other shows that get confused by the year. They can't match properly to existing directories in your libraries. Existing episodes as well as "keep only X shows" and anything related like that will not work properly.
Luke 42217 Posted October 12, 2018 Posted October 12, 2018 We're not going to do that anymore either.
Guest asrequested Posted October 12, 2018 Posted October 12, 2018 It isn't just the picture. It created a new folder and recorded to that as though it was a different show. 1
Guest asrequested Posted October 12, 2018 Posted October 12, 2018 (edited) Here's what I wish we could do, is use identify for recording schedules. Or manually correct the show identity. The episode was correctly named, it just attributed it to the wrong show. Edited October 12, 2018 by Doofus
paulsalter 84 Posted October 12, 2018 Posted October 12, 2018 (edited) Does a fix match at the show level of the recording make any difference This is one i have (its not a remake of a previous one so not sure if that is the issue) Guide data called it White Dragon After the first episode i did a fix match at the show level, to match it against Strangers All the files are still named with White Dragon, but the data it retrieves is all for Strangers Edited October 12, 2018 by paulsalter
Luke 42217 Posted October 12, 2018 Posted October 12, 2018 The identify feature does not rename files. And it does not affect the file name of future recordings. That all comes from guide data.
Guest asrequested Posted October 12, 2018 Posted October 12, 2018 It's an existing schedule. The show is already established. For the new season, it deviated. If we could attribute an identity to the schedule, it should fix it in perpetuity.
Guest asrequested Posted October 12, 2018 Posted October 12, 2018 The identify feature does not rename files. And it does not affect the file name of future recordings. That all comes from guide data. Ok, if identify can't be used, give us a field so we can specify the show folder. If we use that, have it override the guide data and rely on a library scan. 3
paulsalter 84 Posted October 12, 2018 Posted October 12, 2018 Rename the original as The Flash (YYYY) not sure of the year without looking it up Assuming the new ones are just in a folder as 'The Flash', do a fix in metadata manager to point it to the new show I have done this with other shows in the past and it works fine for you library, doesnt change anything in EPG Not sure if your comment was aimed at me, Luke, but i never suggested renaming anything
Guest asrequested Posted October 12, 2018 Posted October 12, 2018 Rename the original as The Flash (YYYY) not sure of the year without looking it up Assuming the new ones are just in a folder as 'The Flash', do a fix in metadata manager to point it to the new show I have done this with other shows in the past and it works fine for you library, doesnt change anything in EPG Not sure if your comment was aimed at me, Luke, but i never suggested renaming anything Did you look at my pictures? Your suggestions can't work. Everytime there's a deviation, the server creates a separate folder, then I manually correct it.
paulsalter 84 Posted October 12, 2018 Posted October 12, 2018 Yes thanks, i looked at your pictures Just offering a solution which has worked for me in similar situations Good luck getting it fixed
Guest asrequested Posted October 17, 2018 Posted October 17, 2018 So am I really going to have to correct this, every week?
