Problem synology 216play
Go to solution Solved by solabc16,
Problems after updating to the latest version published by synology
emby to stop showing the tv guide and I can not see the plugins, I reinstalled everything from 0 and I still the same, some solution?
I put some of the alerts that emby shows me
Check for plugin updates failed
Error: TrustFailure (A call to SSPI failed, see inner exception.) At Emby.Server.Implementations.HttpClientManager.HttpClientManager + d__18.MoveNext () [0x006b6] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager + d__15.MoveNext () [0x001f4] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.Updates.InstallationManager + d__48.MoveNext () [0x000c0] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.Updates. InstallationManager + d__57.MoveNext () [0x000a5] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask + d__7.MoveNext () [ 0x000a1] in <8252e501 22f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker + d__68.MoveNext () [0x00156] in <8252e50122f84f82af882c36d707f6ce>: 0
Check for application updates failed
Error: TrustFailure (A call to SSPI failed, see inner exception.) At Emby.Server.Implementations.HttpClientManager.HttpClientManager + d__18.MoveNext () [0x006b6] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.HttpClientManager.HttpClientManager + d__15.MoveNext () [0x001f4] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at MediaBrowser.Common.Updates.GithubUpdater + d__3.MoveNext () [0x000f6] in <8096af2ef9e24d15a1a7abee7f8324c0>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.ApplicationHost + d__382. MoveNext () [0x00136] in <8252e50122f84f82af882c36d707f6ce>: 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.ScheduledTasks.SystemUpdateTask + d__11.MoveNext () [0x00086] in < 8252e50122f84f82af882c36d707f6ce> : 0 --- End of stack trace from previous location where exception was thrown --- at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker + d__68.MoveNext () [0x00156] in <8252e50122f84f82af882c36d707f6ce>: 0
Thanks for the update @@alex553, and sorry for the inconvenience.
As a rule of thumb - for future readers stumbling across this post, if you do have issues after an upgrade then do not uninstall, as they can almost always be resolved. Your configuration will be ok, even if Emby Server won't run for some reason.
For Emby Premiere users, make use of the 'Backup and Restore' plugin! For a manual belt and braces solution, see my post here: https://emby.media/community/index.php?/topic/63686-emby-3530-1-ds212j-ko/?p=632558
Best
- James
