EODCrafter 181 Posted October 9, 2018 Posted October 9, 2018 (edited) Not Emby related but I hope someone has experience and can help me...... I would like to put in a Windows network share path to a XML Guide file I have Windows Task Scheduler Building once a week instead of having to upload the file manually to my Android Nvidia Shield Server. There is no Android Equivalent of Zap2Xml as far as I know. No matter what path I put in the TV Guide Data Providers Emby doesn't recognize the Path. The actual Windows Share is \\STEVE\TVGuide and the local IP is 192.168.1.114. How do I share this to the Android Server on Nvidia Shield? Do I need to install some special Android App like Android SMB or something? I have tried: http:\\192.168.1.114\STEVE\Guide\xmltv.xml smb:\\STEVE\Guide\xmltv.xml \\STEVE\Guide\xmltv.xml What am I missing? Also, I have the Share to "everyone" so access shouldn't be an issue. Edited October 9, 2018 by EODCrafter
Luke 42237 Posted October 9, 2018 Posted October 9, 2018 Use the ip address rather than machine name, and it will need to be shared anonymously.
EODCrafter 181 Posted October 9, 2018 Author Posted October 9, 2018 I don't think it works anymore...
Luke 42237 Posted October 9, 2018 Posted October 9, 2018 Looks like the server does not have access to the folder.
EODCrafter 181 Posted October 9, 2018 Author Posted October 9, 2018 (edited) Looks like the server does not have access to the folder. I figured you might suggest that.... I've been Googling also and People are reporting this as a possible Bug with the Windows 10 Creator Update...IDK. Oh Well, Manual upload once a week until someone creates a Zap2Xml Parser for Android. Edited October 9, 2018 by EODCrafter
EODCrafter 181 Posted October 10, 2018 Author Posted October 10, 2018 Thanks for the feedback. Finally got it @@Luke...This is the correct path.....
Luke 42237 Posted October 10, 2018 Posted October 10, 2018 thanks for the feedback. based on that i would have also expected \\192.168.1.114\TVGuide\xmltv.xml to also work. but definitely not the http one as this is not the http protocol. 1
EODCrafter 181 Posted October 10, 2018 Author Posted October 10, 2018 (edited) thanks for the feedback. based on that i would have also expected \\192.168.1.114\TVGuide\xmltv.xml to also work. but definitely not the http one as this is not the http protocol. It adds the smb: in there by itself but only when you add the trailing \ and click on a folder...Networking just freaks me out sometimes Perhaps you could update your Cheat Sheet up there ^^^^^^^^ and add the trailing \ for Dummies like me. Edited October 10, 2018 by EODCrafter
EODCrafter 181 Posted October 10, 2018 Author Posted October 10, 2018 (edited) Huh, weird...None of the Mapping shows up and no guide data is imported..... It Maps fine when I directly upload the file...... @@ebr @@Luke Here's the log that shows the error.... 2018-10-10 19:07:31.879 Info HttpServer: HTTP Response 200 to 192.168.1.114. Time: 9ms. http://192.168.1.130:8096/emby/ScheduledTasks?IsEnabled=true 2018-10-10 19:07:31.966 Error HttpServer: Error processing request *** Error Report *** Version: 3.6.0.53 Command line: /data/app/com.emby.embyserver-TmhuGh6IhGEeqHKZvGuvCw==/base.apk Operating system: Unix 3.10.96.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Processor count: 4 Program data path: /storage/emulated/0/Android/data/com.emby.embyserver/files Application directory: /data/user/0/com.emby.embyserver Mono: 5.12.0 (tarball) Android Version: 8.0.0-REL - SDK: 26 'O' Patch Level: 2604118_1256.7693 (2018-06-01) Fingerprint: NVIDIA/foster_e_hdd/foster:8.0.0/OPR6.170623.010/2604118_1256.7693:user/release-keys Model: SHIELD Android TV - NVIDIA/NVIDIA Hardware: foster/foster_e_hdd/foster_e_hdd/unknown SupportedAbis: arm64-v8a, armeabi-v7a, armeabi System.NotSupportedException: The URI prefix is not recognized. Source: mscorlib TargetSite: Void Throw() at System.Net.WebRequest.Create (System.Uri requestUri, System.Boolean useUriBase) [0x000ae] in <b78695579ed9422b8bc80218eeda782c>:0 at System.Net.WebRequest.Create (System.Uri requestUri) [0x00014] in <b78695579ed9422b8bc80218eeda782c>:0 at System.Xml.XmlDownloadManager.GetNonFileStream (System.Uri uri, System.Net.ICredentials credentials, System.Net.IWebProxy proxy, System.Net.Cache.RequestCachePolicy cachePolicy) [0x00000] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlDownloadManager.GetStream (System.Uri uri, System.Net.ICredentials credentials, System.Net.IWebProxy proxy, System.Net.Cache.RequestCachePolicy cachePolicy) [0x00022] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlUrlResolver.GetEntity (System.Uri absoluteUri, System.String role, System.Type ofObjectToReturn) [0x00032] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlTextReaderImpl.FinishInitUriString () [0x0004c] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlTextReaderImpl..ctor (System.String uriStr, System.Xml.XmlReaderSettings settings, System.Xml.XmlParserContext context, System.Xml.XmlResolver uriResolver) [0x000c7] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlReaderSettings.CreateReader (System.String inputUri, System.Xml.XmlParserContext inputContext) [0x0003b] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlReader.Create (System.String inputUri, System.Xml.XmlReaderSettings settings, System.Xml.XmlParserContext inputContext) [0x0000a] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at System.Xml.XmlReader.Create (System.String inputUri, System.Xml.XmlReaderSettings settings) [0x00000] in <a26bd4a8d2534df8b37395d4ed1cdbfd>:0 at Emby.XmlTv.Classes.XmlTvReader.CreateXmlTextReader (System.String path) [0x00022] in <bb8c768795224ef79a91600891059ae1>:0 at Emby.XmlTv.Classes.XmlTvReader.GetChannels () [0x00006] in <bb8c768795224ef79a91600891059ae1>:0 at Emby.Server.Implementations.LiveTv.Listings.XmlTvProvider+<GetChannels>d__22.MoveNext () [0x000bd] in <b888900d7e9d4d0bb42c1bbcec5adcfa>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <43dbbdc147f2482093d8409abb04c233>:0 at MediaBrowser.Api.LiveTv.LiveTvService+<Get>d__21.MoveNext () [0x001a9] in <1f8a0674c28c4224b6166ec709f9de47>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <43dbbdc147f2482093d8409abb04c233>:0 at Emby.Server.Implementations.Services.ServiceExecGeneral+<GetTaskResult>d__3.MoveNext () [0x00081] in <b888900d7e9d4d0bb42c1bbcec5adcfa>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <43dbbdc147f2482093d8409abb04c233>:0 at Emby.Server.Implementations.Services.ServiceHandler+<ProcessRequestAsync>d__13.MoveNext () [0x00237] in <b888900d7e9d4d0bb42c1bbcec5adcfa>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0003e] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x00028] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x00008] in <43dbbdc147f2482093d8409abb04c233>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <43dbbdc147f2482093d8409abb04c233>:0 at Emby.Server.Implementations.HttpServer.HttpListenerHost+<RequestHandler>d__56.MoveNext () [0x00af1] in <b888900d7e9d4d0bb42c1bbcec5adcfa>:0 2018-10-10 19:07:31.969 Info HttpServer: HTTP Response 500 to 192.168.1.114. Time: 876ms. http://192.168.1.130:8096/emby/LiveTv/ChannelMappingOptions?providerId=58febddb8c1e4890904f09560ee969c2 2018-10-10 19:07:32.870 Info HttpServer: HTTP GET http://192.168.1.130:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36 Edited October 11, 2018 by EODCrafter
