Ciberdream 1 Posted October 8, 2018 Posted October 8, 2018 Hi, Im trying to set up Emby server on DS218Play and client on Sony android TV. I folow guide and install server and install app on TV but i dont see my files. I already have folders shared and can access them with kodi, plex etc but emby dont see server. When i click on url link in package center get message " this site cant be reached" in chrome. Also i cant open site with Microsoft Edge. Im runing windows 10. I dont know how to add server on app.emby.media. Where can i find emby server IP address and port? What am i doing wrong?
FrostByte 5453 Posted October 8, 2018 Posted October 8, 2018 (edited) The Emby server IP will be the same as your NAS and the port default is 8096 (if dual NIC it will be one of the two IPs). Though I'm not sure why package center isn't bringing up the page PC should open link like this http://192.168.XX.XXX:8096/web/index.html#!/dashboard.html Edited October 8, 2018 by FrostByte
Ciberdream 1 Posted October 8, 2018 Author Posted October 8, 2018 Thank you for your answer. I try with nas IP and default port but not working. Maybe is something with Synology settings? What is important for Emby server? Maybe I changed something before. Can I do factory reset without changing folders and files?
solabc16 379 Posted October 8, 2018 Posted October 8, 2018 Hello @@Ciberdream From what you've described, that sounds like Emby Server isn't actually running. Are you able to run the send logs utility? https://github.com/MediaBrowser/Wiki/wiki/Synology-:-How-to-Send-us-Support-Logs Best - James
FrostByte 5453 Posted October 9, 2018 Posted October 9, 2018 I had something similar this morning after adding the MusicBrainz plugin. I stopped Emby in PC and restarted. Clicked on Open and it was like Emby wasn't really running. So I stopped it again and restarted and everything is good now. You could try that
Ciberdream 1 Posted October 17, 2018 Author Posted October 17, 2018 I manage to get my emby player to work. I simply open server setings in PC-Network-Media Devices and add folder with my movies. Emby app on my TV not playing very good but EmbyCon addon for Kodi is ok, plays 4K movies with DTS sound without problem. thank you all 1
Luke 42241 Posted October 18, 2018 Posted October 18, 2018 Hi, what Emby app for your TV are you referring to?
Ciberdream 1 Posted October 18, 2018 Author Posted October 18, 2018 Is Emby for Android TV from Google Playstore
Luke 42241 Posted October 18, 2018 Posted October 18, 2018 Are you able to browse your files using the Emby web app?
