laola 12 Posted October 12, 2018 Posted October 12, 2018 I do have the same issue - should I just wait for an updated version or should I replace the py as well ?
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 I would try to replace the py. (make a backup from the old one)
Angelblue05 4132 Posted October 12, 2018 Posted October 12, 2018 (edited) Check for updates in the addon settings > advanced. That should pick up on the fix that was just pushed to github. Edited October 12, 2018 by Angelblue05
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 I'm scared! I just have a running system again
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 We just pushed the changes to the repo ^^ Plus fixed another small one that was introcuded with the file I gave you. No need to worry. 1
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 After installing the update and patch was applied: Results: Resuming a movie via widget -> resume at(resuming time): passed Playing a new movie via widget: passed Resuming a movie via widget -> context menu -> resume at(resuming time): kodi crashed Playing a new movie via widget -> context menu -> play: kodi crashed Resuming a movie via widget -> context menu -> information -> resume: kodi crashed Changed the settings -> media -> videos -> default action = show information Resuming a video: passed Playing a new video: crash kodi
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 (edited) Have you restarted after the patch has been applied? This was required on my end at home. Edited October 12, 2018 by sualfred
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 I restarted the box after each crash completely (incl. making the box powerless)
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 (edited) Please open the exisitng actions.py on your box and scroll down to the bottom. To this part: ..... elif not isPlaying and window('emby.playinfo.bool') and not xbmc.getCondVisibility('Window.IsVisible(DialogContextMenu.xml)'): window('emby.context.count', value=str(count + 1)) if count == 2: window('emby.playinfo', clear=True) window('emby.context.count', clear=True) elif not isPlaying and window('emby.context.widget.bool') and not xbmc.getCondVisibility('Window.IsVisible(DialogVideoInfo.xml)'): window('emby.context.count', value=str(count + 1)) if count == 2: window('emby.context.widget', clear=True) window('emby.context.count', clear=True) Please change both lines from "if count == 2" to "if count == 3" And test it again. If that doesn't work increase it to 4. If that also doesn't work try 5 and 6. Also don't forget to restart Kodi after replacing the values and let us know if another value works. Edited October 12, 2018 by sualfred
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 changed the value up to "6", same results (kodi still crashes)
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 How long does it take until your playback starts?
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 changing back to the action.py you gave me yesterday. It works again, even via context menu.
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 (edited) Please change to the current one and increase the count to something very like 100 Edited October 12, 2018 by sualfred
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 (edited) 100 works decreasing the value to 25: still works fine Edited October 12, 2018 by Volkmar
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 Please try to decrease it more and let me know the lowest possible value.
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 Ok. Race condition issue. I have an idea which works on my end. Please go to your default addon folder: /addons/plugin.video.emby/resources/lib/database and edito _init_.py:From this try: from objects import obj except Exception as error: # clear patch LOG.exception(error) delete_folder() dialog("ok", heading="{emby}", line1=_(33155)) xbmc.executebuiltin('RestartApp') to this try: from objects import obj except Exception as error: pass And after that please replace the actions.py in the hidden folder again with the one that is attached to this post.If that still does not work please increase the count value again and let me know if the minimum required count value is lower than before. actions.zip
Volkmar 14 Posted October 12, 2018 Author Posted October 12, 2018 with value 1 it don't work, I had to increase to value 7 (before it was value 8)
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 Hmm ok. We will look into it. At least it works for you for the moment. 1
sualfred 677 Posted October 12, 2018 Posted October 12, 2018 (edited) @@Volkmar Could you please try the attached actions.py? And increase the count value again until it works. actions.zip Edited October 12, 2018 by sualfred
Volkmar 14 Posted October 13, 2018 Author Posted October 13, 2018 I didn't had to increase the value. It works to me as it is (value 1). /addons/plugin.video.emby/resources/lib/database/_init_.py is still modified. 2
sualfred 677 Posted October 13, 2018 Posted October 13, 2018 That's what I wanted to hear. Great. Thanks 1
Angelblue05 4132 Posted October 13, 2018 Posted October 13, 2018 I will apply the changes by sualfred. Thank you for confirming this resolves the situation. 1
Angelblue05 4132 Posted October 13, 2018 Posted October 13, 2018 @@Volkmar Let's try this again, in the add-on settings > advanced > check for updates. Let me know if everything still works. We found a small error in the code, which I've corrected in the process. 1
