carljames 0 Posted October 7, 2018 Posted October 7, 2018 Hi I have an m3u setup in EMBY along with guide data and it works awesome for hours and then I get the "tuner not available" error. I have to manually restart EMBY and sometimes reboot the server and it seems to fix this issue for a little while? I've tried cutting on/off transcoding. Any help guys and thanks in advance
carljames 0 Posted October 7, 2018 Author Posted October 7, 2018 I aslo have the m3u file on the server as opposed to a remote m3u link.
carljames 0 Posted October 7, 2018 Author Posted October 7, 2018 (edited) I enabled log debugging if you'd like to have a look...and I'm using the Android apple Roku and web versions of emby. The server is running remote on linux Edited October 7, 2018 by carljames
maegibbons 1287 Posted October 7, 2018 Posted October 7, 2018 Yes attach the FULL emby log. I may be wrong and I forget where i saw it but feel there may be an issue on the Roku if you dont back out of a stream correctly - like pressing the home key. The roku app cannot detect it and hence the stream is not stopped on ths erver for a while. Krs Mark
Luke 42244 Posted October 7, 2018 Posted October 7, 2018 Hi, yes can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
carljames 0 Posted October 27, 2018 Author Posted October 27, 2018 Hi sorry ittook so long. I believe this is the issue 2018-10-17 08:31:30.591 Info HttpServer: HTTP Response 404 to 45.49.57.9. Time: 1ms. http://148.72.152.143:8096/emby/Items/30e5a9491d7260f202d87e70610068bc/Images/Primary?Accept=webp&PercentPlayed=11&EnableImageEnhancers=true&MaxHeight=300&Tag=10c4a58b1e74ea6a4a8096f5a353c0de 2018-10-17 08:31:31.051 Info HttpServer: HTTP POST http://148.72.152.143:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 5.1.1; AFTT Build/LVY48F) 2018-10-17 08:31:31.052 Info HttpServer: HTTP Response 204 to 73.232.255.122. Time: 1ms. http://148.72.152.143:8096/emby/Sessions/Playing/Progress 2018-10-17 08:31:31.252 Info HttpServer: HTTP POST http://148.72.152.143:8096/emby/Sessions/Playing/Progress. UserAgent: Dalvik/2.1.0 (Linux; U; Android 5.1.1; AFTT Build/LVY48F) 2018-10-17 08:31:31.253 Info HttpServer: HTTP Response 204 to 73.232.255.122. Time: 1ms. http://148.72.152.143:8096/emby/Sessions/Playing/Progress 2018-10-17 08:31:31.506 Info HttpServer: HTTP GET http://148.72.152.143:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Linux; Android 8.0.0; VS988 Build/OPR1.170623.032; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/69.0.3497.100 Safari/537.36 2018-10-17 08:31:31.507 Info HttpServer: HTTP Response 200 to 24.216.112.209. Time: 1ms. http://148.72.152.143:8096/emby/system/info/public 2018-10-17 08:31:31.586 Info HttpServer: HTTP GET http://148.72.152.143:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Linux; Android 8.0.0; VS988 Build/OPR1.170623.032; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/69.0.3497.100 Safari/537.36 2018-10-17 08:31:31.591 Info HttpServer: HTTP GET http://emby2.ddns.net:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Linux; Android 8.0.0; VS988 Build/OPR1.170623.032; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/69.0.3497.100 Safari/537.36 2018-10-17 08:31:31.591 Info HttpServer: HTTP Response 200 to 24.216.112.209. Time: 0ms. http://emby2.ddns.net:8096/emby/system/info/public 2018-10-17 08:31:32.088 Info HttpServer: HTTP GET http://148.72.152.143:8096/emby/Items/30e5a9491d7260f202d87e70610068bc/Images/Primary?Accept=webp&PercentPlayed=11&EnableImageEnhancers=true&MaxHeight=300&Tag=10c4a58b1e74ea6a4a8096f5a353c0de. UserAgent: Dalvik/2.1.0 (Linux; U; Android 8.0.0; SHIELD Android TV Build/OPR6.170623.010) 2018-10-17 08:31:32.089 Error HttpServer: Error processing request *** Error Report *** Version: 3.5.3.0 Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.15.0.29 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: /var/lib/emby Application directory: /opt/emby-server/system MediaBrowser.Common.Extensions.ResourceNotFoundException: Item 30e5a9491d7260f202d87e70610068bc not found. at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Guid itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute(Type serviceType, IRequest request, Object instance, Object requestDto, String requestName) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IHttpRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken) MediaBrowser.Common.Extensions.ResourceNotFoundException at MediaBrowser.Api.Images.ImageService.GetImage(ImageRequest request, Guid itemId, BaseItem item, Boolean isHeadRequest) at Emby.Server.Implementations.Services.ServiceExecGeneral.Execute(Type serviceType, IRequest request, Object instance, Object requestDto, String requestName) at Emby.Server.Implementations.Services.ServiceController.Execute(HttpListenerHost appHost, Object requestDto, IRequest req) at Emby.Server.Implementations.Services.ServiceHandler.ProcessRequestAsync(HttpListenerHost appHost, IRequest httpReq, IResponse httpRes, ILogger logger, String operationName, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpServer.HttpListenerHost.RequestHandler(IHttpRequest httpReq, String urlString, String host, String localPath, CancellationToken cancellationToken)
Luke 42244 Posted October 27, 2018 Posted October 27, 2018 Hi there, can you please attach the full and complete emby server log? thanks.
carljames 0 Posted October 27, 2018 Author Posted October 27, 2018 (edited) Thanks Luke pm sent Edited October 27, 2018 by carljames
Luke 42244 Posted October 28, 2018 Posted October 28, 2018 There's nothing obvious here. You could try enabling the auto loop setting on the m3u tuner.
