EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 Does anyone have a tutorial on solving this issue with NPVR? I heard it mentioned that this is a solution, but how exactly?
hooray4me 52 Posted January 22, 2019 Posted January 22, 2019 This is how we did it with TVHeadend... TVHeadEnd is co-located on the same server as Emby. The Emby server has a couple nics and I dedicated a nic and a small /29 network specifically for the the HDHomeRun Prime tuners. iface enp9s0f0 inet static address 10.50.3.249 netmask 255.255.255.248 broadcast 10.50.3.255 network 10.50.3.248 up ip route add 10.50.3.248/29 dev enp9s0f0 table enp9s0f0 up ip route add default via 10.50.3.254 dev enp9s0f0 table enp9s0f0 up ip rule add from 10.50.3.249/32 table enp9s0f0 up ip rule add to 10.50.3.249/32 table enp9s0f0 TVHeadend should see the tuners automatically. You’ll want to go into the tuners ahead of time and favorite the channels you want to see and X the ones you don’t… we filter out all non-HD channels. Next you need to create the base of your M3U file. We have 2 tuners so I need to create a file for each one… I name them temporarily with the serial number of the homerun so I can tell them apart and save it to the tmp directory echo "#EXTM3U" > /tmp/1323B05B.m3u | curl "http://10.50.3.250/lineup.xml"|sed 's/<GuideNumber>/#EXTINF\:<GuideNumber>/g' | sed 's/<\/GuideNumber>/\,<\/GuideNumber>/g' | sed -e 's/<[^>]*>//g' | sed 's/http/\ http/g' | sed 's/http/\nhttp/g' | sed 's/\&\;/\&/g' | sed 's/MPEG.*//' | sed 's/H264.*//' >> /tmp/1323B05B.m3u echo "#EXTM3U" > /tmp/1322A20B.m3u | curl "http://10.50.3.251/lineup.xml"|sed 's/<GuideNumber>/#EXTINF\:<GuideNumber>/g' | sed 's/<\/GuideNumber>/\,<\/GuideNumber>/g' | sed -e 's/<[^>]*>//g' | sed 's/http/\ http/g' | sed 's/http/\nhttp/g' | sed 's/\&\;/\&/g' | sed 's/MPEG.*//' | sed 's/H264.*//' >> /tmp/1322A20B.m3u Next download the files so you can edit them. The base of the file will look like this: #EXTM3U #EXTINF:701,WATL_HD http://10.50.3.251:5004/auto/v701 #EXTINF:702,WSB_ABC http://10.50.3.251:5004/auto/v702 #EXTINF:703,QVC HD http://10.50.3.251:5004/auto/v703 You will need to edit each one to get it into this format, I use notepad++ and excel #EXTINF:-1 tvh-chnum="701" m3u-name="WATL_HD",WATL_HD http://10.50.3.251:5004/auto/v701 #EXTINF:-1 tvh-chnum="702" m3u-name="WSB_ABC",WSB_ABC http://10.50.3.251:5004/auto/v702 #EXTINF:-1 tvh-chnum="703" m3u-name="QVC HD",QVC_HD http://10.50.3.251:5004/auto/v703 Next I save each file in a directory on the server named for its serial number and save it as lineup.m3u /home/hts/.hts/tvheadend/scan/1322A20B/lineup.m3u /home/hts/.hts/tvheadend/scan/1322B20B/lineup.m3u In TVheadend create a new IPTV Automatic Network for each tuner. After it scan each url that was included in the M3U it will create a MUX for it. Then you auto map the muxes to the service and it will create the channels 1
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 (edited) Whew...lol @robrhedrick what a mess! I can't even get NPVR to allow another IPTV Source........ Edited January 22, 2019 by EODCrafter
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 (edited) Ahhhh....I guess @@sub3 no longer supports it...... Edited January 22, 2019 by EODCrafter
sub3 64 Posted January 22, 2019 Posted January 22, 2019 @@EODCrafter, NextPVR still supports IPTV. This wiki page is out of date. That was actually about something else. The term "IPTV" is used for lots of different types of technologies. Back then NextPVR support unicast/multicast IPTV, as used by some hotels and some cable companies, for use on their own networks. (as opposed to the now more commonly thought of "IPTV", where users are viewing TS/HLS streams across the internet from pirate IPTV providers, which we initially added support for in about v3.8) I'll remove that bit of text to remove any confusing in the future.
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 @@EODCrafter, NextPVR still supports IPTV. This wiki page is out of date. That was actually about something else. The term "IPTV" is used for lots of different types of technologies. Back then NextPVR support unicast/multicast IPTV, as used by some hotels and some cable companies, for use on their own networks. (as opposed to the now more commonly thought of "IPTV", where users are viewing TS/HLS streams across the internet from pirate IPTV providers, which we initially added support for in about v3.8) I'll remove that bit of text to remove any confusing in the future. Ok, Sry, But what about adding more than 1 IPTV Source as been suggested in this thread?
Carlo 4561 Posted January 22, 2019 Posted January 22, 2019 (edited) Ok, Sry, But what about adding more than 1 IPTV Source as been suggested in this thread? In NextPVR can't you just take the 2nd M3U file and append it to the first file so it's twice as big. Then after importing it use the group function to combine them? Edited January 23, 2019 by cayars 1
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 (edited) In NextPVR can't you just take the 2nd M3U file and append it to the first file so it'w twice as big. Then after importing it use the group function to combine them? I'll try that next time I'm on Windows.......I tried importing it by the m3u file (didn't import, just replaced other one). With all the channel names the same it may be out of the scope of NPVR. I had m3u1 and m3u2...added m3u1, then imported m3u2 and channels were only recognized from m3u2. Edited January 22, 2019 by EODCrafter
sub3 64 Posted January 22, 2019 Posted January 22, 2019 Ok, Sry, But what about adding more than 1 IPTV Source as been suggested in this thread? You can just 'import' button as many times as you want with that one IPTV source.
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 (edited) You can just 'import' button as many times as you want with that one IPTV source. I tried that....Didn't recognize 2nd login as a new source, just replaced old one. All the channel names are the same with a different password for stream login..... Edited January 22, 2019 by EODCrafter
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 Was it the same url? or a different url? url is different cause password is in url.
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 (edited) htts://go.vaders.iptv/get.php?username=*********@.com&password=*********&type=m3u_plus&output=mpegts whatever...won't let me post it right......the next streams will have a different password. or I just insert that in a browser and download the m3u's complete but NPVR only accepts one listing I never get the separate listing. Even if I did I suspect it will be double channels which is the original problem we have. Edited January 22, 2019 by EODCrafter
EODCrafter 181 Posted January 22, 2019 Posted January 22, 2019 (edited) Here's what the m3u looks like @@sub3 #EXTM3U #EXTINF:-1 tvg-ID="" tvg-name="AU: Fox NRL League HD" tvg-logo="https://upload.wikimedia.org/wikipedia/commons/thumb/5/56/Fox_Sports_logo1.svg/220px-Fox_Sports_logo1.svg.png" group-title="Sports",AU: Fox NRL League HD http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/53441 #EXTINF:-1 tvg-ID="Ginx Esports CA" tvg-name="CA: Ginx Esports TV" tvg-logo="https://upload.wikimedia.org/wikipedia/commons/thumb/3/30/GINX_Esports_TV_Logo.png/200px-GINX_Esports_TV_Logo.png" group-title="Sports",CA: Ginx Esports TV http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/53174 #EXTINF:-1 tvg-ID="Golf Channel CA" tvg-name="CA: Golf Channel UHD" tvg-logo="http://cdn.cablefax.com/wp-content/uploads/2014/06/golf-logo.jpg" group-title="Sports",CA: Golf Channel UHD http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/45062 #EXTINF:-1 tvg-ID="Golf Channel CA" tvg-name="CA: Golf Channel" tvg-logo="http://cdn.cablefax.com/wp-content/uploads/2014/06/golf-logo.jpg" group-title="Sports",CA: Golf Channel We need to link it like this.....and recognize one channel is already in use......probably impossible...... #EXTINF:-1 tvg-ID="" tvg-name="AU: Fox NRL League HD" tvg-logo="https://upload.wikimedia.org/wikipedia/commons/thumb/5/56/Fox_Sports_logo1.svg/220px-Fox_Sports_logo1.svg.png" group-title="Sports",AU: Fox NRL League HD http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/53441 http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/987654321/53441 ect...... Edited January 23, 2019 by EODCrafter
sub3 64 Posted January 23, 2019 Posted January 23, 2019 url is different cause password is in url. You should be able to do that. I don't have any way to easily test it though. If you want me to give it a quick test with your credentials, you can PM me the two URLS and I'll try to see what happens.
EODCrafter 181 Posted January 23, 2019 Posted January 23, 2019 (edited) You should be able to do that. I don't have any way to easily test it though. If you want me to give it a quick test with your credentials, you can PM me the two URLS and I'll try to see what happens. family watching 1 url in living room.......sry, but thx for your effort. if you log in my account can be termed........they track them by recognized IP addresses now.......Too many people starting there own streaming service using IPTV as their source...lol Edited January 23, 2019 by EODCrafter
sub3 64 Posted January 23, 2019 Posted January 23, 2019 family watching 1 url in living room.......sry, but thx for your effort. if you log in my account can be termed........they track them by recognized IP addresses now....... Ok, no worries. (I have look at several other people's vader issues this way without problems in the past)
EODCrafter 181 Posted January 23, 2019 Posted January 23, 2019 (edited) Ok, no worries. (I have look at several other people's vader issues this way without problems in the past) I don't have vaders...my iptv is very low key.....Vaders offer 5 streams per login anyway...mine only 1. Edited January 23, 2019 by EODCrafter
hooray4me 52 Posted January 23, 2019 Posted January 23, 2019 This is the functionality we're asking for and have been told that it will be coming this year. The only workaround I know is through TVHeadEnd. Here's what the m3u looks like @@sub3 #EXTM3U #EXTINF:-1 tvg-ID="" tvg-name="AU: Fox NRL League HD" tvg-logo="https://upload.wikimedia.org/wikipedia/commons/thumb/5/56/Fox_Sports_logo1.svg/220px-Fox_Sports_logo1.svg.png" group-title="Sports",AU: Fox NRL League HD http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/53441 #EXTINF:-1 tvg-ID="Ginx Esports CA" tvg-name="CA: Ginx Esports TV" tvg-logo="https://upload.wikimedia.org/wikipedia/commons/thumb/3/30/GINX_Esports_TV_Logo.png/200px-GINX_Esports_TV_Logo.png" group-title="Sports",CA: Ginx Esports TV http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/53174 #EXTINF:-1 tvg-ID="Golf Channel CA" tvg-name="CA: Golf Channel UHD" tvg-logo="http://cdn.cablefax.com/wp-content/uploads/2014/06/golf-logo.jpg" group-title="Sports",CA: Golf Channel UHD http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/45062 #EXTINF:-1 tvg-ID="Golf Channel CA" tvg-name="CA: Golf Channel" tvg-logo="http://cdn.cablefax.com/wp-content/uploads/2014/06/golf-logo.jpg" group-title="Sports",CA: Golf Channel We need to link it like this.....and recognize one channel is already in use......probably impossible...... #EXTINF:-1 tvg-ID="" tvg-name="AU: Fox NRL League HD" tvg-logo="https://upload.wikimedia.org/wikipedia/commons/thumb/5/56/Fox_Sports_logo1.svg/220px-Fox_Sports_logo1.svg.png" group-title="Sports",AU: Fox NRL League HD http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/123456789/53441 http://go.vaders.iptv:80/joe.blow@[member="gmail"].com/987654321/53441 ect......
EODCrafter 181 Posted January 23, 2019 Posted January 23, 2019 (edited) This is the functionality we're asking for and have been told that it will be coming this year. The only workaround I know is through TVHeadEnd. I couldn't figure out tvheadend...sry...way too techy. I added my sources and 5 minutes later it recognized 7 services with 18,000 to go...not sure what is was scanning but that would take a month to scan all the services. Edited January 23, 2019 by EODCrafter
hooray4me 52 Posted January 23, 2019 Posted January 23, 2019 We'll custom usage such as this is pretty techy
EODCrafter 181 Posted January 23, 2019 Posted January 23, 2019 We'll custom usage such as this is pretty techy How long did it take to scan all your channels or are you using a tuner card instead of IPTV?
hooray4me 52 Posted January 23, 2019 Posted January 23, 2019 initial scan in TVHeadend was maybe 10 minutes? 200 channels or so... How long did it take to scan all your channels or are you using a tuner card instead of IPTV? 1
Senna 368 Posted January 23, 2019 Posted January 23, 2019 (edited) This is the functionality we're asking for and have been told that it will be coming this year. The only workaround I know is through TVHeadEnd. Good old DVBLink (from DVBLogic) has a perfect solution that I find the most easy, that even non-tech nerds can understand. It has a Channel Merge feature, where you can drag and drop channels of different sources (IPTV, DVB-C etc) into ONE Channel, where the user decides which channel source gets used FIRST by DVBLink when a user opens a channel. The order in this Merge List than decides which Source is used first. So with this you can have multiple sources of a channel that act as one, in whatever media software package you request the channel. Info button from screenshot: On this configuration tab you can merge channels from different signal sources. Merging channels from different sources into a single logical channel allows DVBLink Server to perform efficient tuner sharing among all its clients. The channels can be merged by dragging and dropping them on another channel or in automated way like merging by channel name or by channel number. DVBLogic says now, that from their software packages, TVMosaic is King, because DVBLink is End of Life and sales/support for DVBLink has been discontinued from January this year.... But to me DVBLink is still KING, because it has feature options (like Channel Merge from DIFFERENT sources and more) that are still MISSING in TVMosaic.... Edited January 23, 2019 by Senna 1
EODCrafter 181 Posted January 23, 2019 Posted January 23, 2019 (edited) Might as well just Pay for Cable.......... Edited January 23, 2019 by EODCrafter
