guerlando 0 Posted October 7, 2018 Posted October 7, 2018 Fresh installation on raspberry pi B+ gives pi@raspberrypi:~ $ sudo journalctl -u emby-server-- Logs begin at Sat 2018-10-06 22:25:17 UTC, end at Sun 2018-10-07 00:53:30 UTC. --Oct 07 00:51:25 raspberrypi systemd[1]: Started Emby Server is a personal media server with apps on just about every device..Oct 07 00:51:26 raspberrypi systemd[1]: emby-server.service: Main process exited, code=killed, status=4/ILLOct 07 00:51:26 raspberrypi systemd[1]: emby-server.service: Unit entered failed state.Oct 07 00:51:26 raspberrypi systemd[1]: emby-server.service: Failed with result 'signal'.Oct 07 00:52:28 raspberrypi systemd[1]: Started Emby Server is a personal media server with apps on just about every device..Oct 07 00:52:28 raspberrypi systemd[1]: emby-server.service: Main process exited, code=killed, status=4/ILLOct 07 00:52:28 raspberrypi systemd[1]: emby-server.service: Unit entered failed state.Oct 07 00:52:28 raspberrypi systemd[1]: emby-server.service: Failed with result 'signal'. I ust did Download emby-server-deb_3.5.3.0_armhf.deb dpkg -i emby-server-deb_3.5.3.0_armhf.deb
guerlando 0 Posted October 7, 2018 Author Posted October 7, 2018 Is it actually armhf? so raspberry is not armhf? How should I install then? THank you so much
Luke 42239 Posted October 7, 2018 Posted October 7, 2018 I think that older model is not armhf. Unfortunately it is not supported at this time.
Mickosx 0 Posted October 9, 2018 Posted October 9, 2018 Hello, I have the same issue with a fresh install. But i have only a Raspberry B : $ cat /proc/cpuinfo processor : 0 model name : ARMv6-compatible processor rev 7 (v6l) BogoMIPS : 697.95 Features : half thumb fastmult vfp edsp java tls CPU implementer : 0x41 CPU architecture: 7 CPU variant : 0x0 CPU part : 0xb76 CPU revision : 7 Hardware : BCM2835 Revision : 000f Serial : 00000000c645fce0 And it's armhf : $ dpkg --print-architecture armhf Any idea ? Thanks
Mickosx 0 Posted October 9, 2018 Posted October 9, 2018 Yes i read this thread. It say that Raspberry Pi B is not armhf while so it is. Is there something that I would not understand?
Luke 42239 Posted October 9, 2018 Posted October 9, 2018 I think the older model is not going to work, sorry.
GiGo 108 Posted January 9, 2019 Posted January 9, 2019 (edited) OK thanks anyway I think the older model is not going to work, sorry. Just a heads up, after trying the Emby Theater setup/images from the other threads, I have managed to get Emby to work on my Raspberry Pie Model B! Well kind of..... Install OSMC and then install the Emby for Kodi add-on, it's rather crude and a little sluggish going through menu's but it works and streams MKV files on my network where my Emby server is powered by my Synology 1815+, very pleased as I now have uses for 2 old Raspberry Model B's! Edited January 9, 2019 by GiGo
