musictalks 2 Posted December 1, 2019 Posted December 1, 2019 Hi. Here is the transcode log. ffmpeg-transcode-f6fb79a3-a944-4bd4-8836-638f73d0ac7b_1.txt
Luke 42233 Posted December 1, 2019 Posted December 1, 2019 Hi. Here is the transcode log. ffmpeg-transcode-f6fb79a3-a944-4bd4-8836-638f73d0ac7b_1.txt This is a live stream you're playing? Emby Server isn't even aware of any subtitles for this video, which means they're likely burnt into the original video.
musictalks 2 Posted December 1, 2019 Posted December 1, 2019 This is live TV. (morning show HD). If the subs were burnt in, wouldn't the LGTV display them without Emby app? The LG is not displaying subs (setting on LG=Off) LG subs displaying (setting-On) Emby is displaying subs. (Emby CC=English or CC=Off)
Luke 42233 Posted December 1, 2019 Posted December 1, 2019 This is live TV. (morning show HD). If the subs were burnt in, wouldn't the LGTV display them without Emby app? The LG is not displaying subs (setting on LG=Off) LG subs displaying (setting-On) Emby is displaying subs. (Emby CC=English or CC=Off) I think I was looking at the wrong log, sorry. So yes it does show dvb_teletext. That's a strange one since we are dropping it from the transcoded output.
SamES 1084 Posted December 1, 2019 Posted December 1, 2019 I think I was looking at the wrong log, sorry. So yes it does show dvb_teletext. That's a strange one since we are dropping it from the transcoded output. The issue is the dvb_teletext appears to be always on when direct playing. Normally turning off closed captions in the tv accessibility menu should disable these, but for some reason it’s not.
Senorgreg 0 Posted March 2, 2020 Posted March 2, 2020 I am experiencing this same issue with live TV on WebOS 4.71.05. Is there any further information on whether this is fixable or a fix is in the works? Thank you.
SamES 1084 Posted March 2, 2020 Posted March 2, 2020 I am experiencing this same issue with live TV on WebOS 4.71.05. Is there any further information on whether this is fixable or a fix is in the works? Thank you. 4.71.05 will be the firmware version. The webOS version should be listed separately. I expect the TV is webos version 1 or 2 http://webostv.developer.lge.com/common-page/faqs/general-how-check-platform-version-my-tv/?&ccm_paging_p=3
Senorgreg 0 Posted March 2, 2020 Posted March 2, 2020 Thank you. Upon closer inspection it says the following, not sure if I have the correct software version yet: webOS TV Version: 4.7.1-50012 (goldilocks2-gulaga)
Senorgreg 0 Posted March 2, 2020 Posted March 2, 2020 (edited) Duplicate post Edited March 2, 2020 by Senorgreg
SamES 1084 Posted March 3, 2020 Posted March 3, 2020 Thank you. Upon closer inspection it says the following, not sure if I have the correct software version yet: webOS TV Version: 4.7.1-50012 (goldilocks2-gulaga) What's the TV model number?
SamES 1084 Posted March 3, 2020 Posted March 3, 2020 (edited) W9 65” OK, then this definitely should not be a problem. Can you please provide the media info for a file you have issues with? The media info from the bottom of the details page for the movie on the server will be fine. Thanks Edited March 3, 2020 by SamES
Senorgreg 0 Posted March 3, 2020 Posted March 3, 2020 OK, then this definitely should not be a problem. Can you please provide the media info for a file you have issues with? The media info from the bottom of the details page for the movie on the server will be fine. Thanks So, this is happening with live content from my HD HomeRun via Emby. Did you need the details of that live connection?
SamES 1084 Posted March 3, 2020 Posted March 3, 2020 So, this is happening with live content from my HD HomeRun via Emby. Did you need the details of that live connection? Right, then these are probably captions, not subtitles which are different. Can you make a recording of the channel for a few minutes, then report that info?
dachouffe 1 Posted March 5, 2020 Posted March 5, 2020 I'm not shure, but i think i have the same problem. I stream my live tv with tvheadend pass thru. Everything looks fine, but when i'm whatching live dutch tv, i get the dutch teletext subtitles. Everything what has something to do with subtitle is disabled. LG 50UM7600PLB webOS TV Version 4.7.1-50717 (goldilocks2-gulaga)
SamES 1084 Posted March 5, 2020 Posted March 5, 2020 try turning closed captions off in the tv settings (under accessibility)
dachouffe 1 Posted March 8, 2020 Posted March 8, 2020 try turning closed captions off in the tv settings (under accessibility) Already tried that, because it was the most logical thing. Played with the emby subtitle setting, tried every combination i could think of. But with no result. The emby client turns on teletext subs when a ducht spoken program is on. The problem only exist with my LG TV webOS, not with android, chromecast or a normal webbrowser. Even tried to remove the teletext steam with TVHeadend, but with no luck. I'm stuck...
dachouffe 1 Posted March 11, 2020 Posted March 11, 2020 Have you got forced subs turned on? @@SamES On emby? Nop, subs are turned of. Even tried choosing different subs, but nothing changed. the're always on... The signal is turned on, when a dutch spoken program on a dutch channel is activated.
SamES 1084 Posted March 11, 2020 Posted March 11, 2020 If you make a recording of this channel, then play it back, do you have the same problem? If so, can you please send me the file via PM?
dachouffe 1 Posted March 12, 2020 Posted March 12, 2020 If you make a recording of this channel, then play it back, do you have the same problem? If so, can you please send me the file via PM? I will try this. I will come back as soon as possible with file.. Thanks..
dachouffe 1 Posted March 15, 2020 Posted March 15, 2020 I will try this. I will come back as soon as possible with file.. Thanks.. Some problems recording with Emby. Will try to test when i resolve this..
SamES 1084 Posted March 15, 2020 Posted March 15, 2020 Some problems recording with Emby. Will try to test when i resolve this.. Can you please send me a PM with a link to this recording that I can download and test (Dropbox, OneDrive, etc)
dachouffe 1 Posted March 15, 2020 Posted March 15, 2020 Can you please send me a PM with a link to this recording that I can download and test (Dropbox, OneDrive, etc) That's the problem on this moment. I can't record with emby. I try to figure out why, but i don't know. As soon as I fix this, I will make the recording available to you. Sorry for the delay.... 1
Slennox 0 Posted July 10, 2020 Posted July 10, 2020 Hi, Any updates on this issue? Any workaround we could test? When playing any Live TV channel whose stream includes subtitles, they are always shown by the LG Web player and can't be disabled. No matter what configuration you select on client or server side. LG Smart TV (55EG920V-ZA) webOS TV 2.2.3-1353 (beehive-biscayne) Emby Theater 1.0.24 Emby Server Versión 4.5.0.13 beta Thank you.
