twiggy2cents 2 Posted October 3, 2018 Posted October 3, 2018 I have two hdhr's on two different antennas, they both have a one or two channels the other doesn't get reliably. If i delete the channel from the hdhr interface on one will emby only record that channel from the one with the listing?
kanipek 230 Posted October 3, 2018 Posted October 3, 2018 That is the way it works for me. I am on cable and have a few of these tuners. Not sure what the issue is but two of my channels on one of the tuners have bad signal, the rest are fine. I disabled those two channels in the HDHR web UI for the tuner and those two channels are only recorded on the other tuners.
Luke 42244 Posted October 4, 2018 Posted October 4, 2018 The answer to this is yes. Once you delete a channel, Emby will not use it for anything at all.
