lonewolfnight 0 Posted October 3, 2018 Posted October 3, 2018 First time install w/ docker 18.03.01, Seems to have issues initiating certain connections to the outside world. Server is publically accessible and does register with Emby account. Web API's are accessible from the server directly. "Check for plugin updates failed" "Check for application updates failed" System.Net.Http.HttpRequestException: No such device or address ---> System.Net.Sockets.SocketException: No such device or address at System.Net.Http.ConnectHelper.ConnectAsync(String host, Int32 port, CancellationToken cancellationToken) Numerous network errors are being thrown in the server log after first setup using current Docker image. Logs https://pastebin.com/fV3ZMLL8 iptables: https://pastebin.com/7Nt5ky0k ip addr: https://pastebin.com/0inzVFRH
Luke 42246 Posted October 3, 2018 Posted October 3, 2018 Hi, your outgoing network communications are failing. Have you configured a network connection for the docker container?
lonewolfnight 0 Posted October 3, 2018 Author Posted October 3, 2018 https://pastebin.com/jNfANBwr I believe so, The docker ip is reachable from internal LAN.
mastrmind11 722 Posted October 3, 2018 Posted October 3, 2018 sounds like an outbound firewall restriction.
lonewolfnight 0 Posted October 3, 2018 Author Posted October 3, 2018 As per the paste bin, the outbound firewall is ACCEPT default.
